Q17 - an audiophile approach to perfect sound
Hello!
I have released a new version of the Q17-Mini PCB with some improvements.
Have a good day,
Stef.
Q17-Mini-1.1.2 release
  • New vertical footprint for coil
  • New SMD footprints on back PCB
  • Update C7/R18 circuit position
  • Some tracks optimisation
  • New 3D and PCB pictures
  • Archived version 1.1.1
https://github.com/stefaweb/Q17-a-QUAD405-audiophile-approach
FQP3 and FQP4 from ex Fairchild sound really great and took me lot of tests (read time and money) to find them.
Is a shame that almost any audio part, that sound good, get obsolete after few years. :(
There are some Toshiba new mosfets, that may fit this application, but I need to simulate, measure and finally listen a lot.
To design a good amplifier you need to listen and compare for each critical part.
Parts matter a lot for those who know how to listen and this take lot of time.
Tibi
Hello,
I am pleased to announce the availability of the Q17-P2 PCB.
Gerber files, dedicated diagram and pictures are available on my GitHub repository.
https://github.com/stefaweb/Q17-a-QUAD405-audiophile-approach/tree/main/Q17-P2
The Q17-P2 is a more evolved version of the Q17-Mini that I previously made based on the Tibi diagram.
The Q17-P2 in brief:
  • Two pairs of FQA Power MOSFET at output.
  • PCB size: 190 x 75 mm (230 mm with soldered power resistors).
  • DC Fuses incorporated on the PCB.
  • Power capacitors of 25mm diameter up to 4700uF.
  • Big footprint for most of the important resistors (can fit Dale).
  • Big footprint for important film capacitors.
  • Optional SMD footprints for C4 and C5 on the back.
  • Optional capacitors at the bottom of the FQA transistors.
  • New optional resistors to protect opamp inputs.
  • Two footprints for C2.
  • New C0 footprint capacitor at input to protect against DC.
  • Integrated jumper to bypass C0 capacitor.
  • New optional D7 Schottky diodes (opamp psu regulation).
  • New 13mm 1.2uF coil using 1.5mm wire for better thermal and current performance.
  • New test points for power lines and speaker output.
Enjoy!
Stef.
Good evening Tibi,
I spent lot of time on it.
I wanted to know if the EXICON ECX10P20 and ECX10N20 are worth the expense with the Q17?
When they will be available. ;)
Otherwise tonight, I plugged the Q17-Mini into a pair of small Dynaudio BM5 (4R and only 87dB sensibility). The Q17 is doing very well. Good mastery of complex filters. I find the sound a little "bright" on the Dynaudio but it is subjective since it was before connected to a pair of old speakers from the 70s (Jennings Contrara) which are far from neutral. In any case, it is very reliable. He turns ten hours a day in background music in my desk.
I will also order some OPA1611 to see if I hear a difference. I generally like bi-polar.
Stef.
With Exicon laterals you can go for 4 pairs of ECW20N20 and ECW20P20. These are double die and do not need source resistor (ballast resistor).
I have implemented Q17 with 4 such pairs at +/-90V achieving 1000W in 4 ohm. A picture is on my twitter account.
These are in stock at https://www.profusionplc.com/type/lateral-mosfet?mnf=exicon
Thanks to high Vds, with laterals, you may achieve impressive power.
On other hand, a single pair of Fairchild's have higher transconductance than 4 pairs of Exicon duble die laterals. Fairchild's will offer low output impedance making Q17 ideal for audiophile speakers.
With laterals, the sound is soft, easy to listen. With Fairchild's, sound is very well defined, with punch and muscle.
For laterals R11 and R12 must be reduced to 20ohm each.
Tibi
