Pearl 3 Burning Amp 2023
Don't forget that Pearl3 has MC7n15 voltage regulator ICs onboard -- whatever ripple, hash, noise, ick-matter, and yuck-o-rama you provide to Pearl3 on the raw-DC-inputs, is further attenuated by these ICs on the Pearl3 board itself. Pearl3 filters what you give it.
Naturally I recommend using the UDP3 (found here on diyAudio) upstream of Pearl3, for greatest precision. But not everyone can afford the top end of the top end.
Putting a Jung-Didden SR in front of a MC7n15 regulator is like taking a shower and then putting on streaky underwear. Of course it will be "obviated"!
Reactions: mhenschel
These were sent to me from PASS DIY with my Pearl 2 boards.
Then there should be no reason to measure, unless the pre matched ones are mixed up
they sent SK170 in your kit? I will have to open mine up and take a look, was thinking the supplied smd in that position?
@maxellfullmon, not sure who has built the Pearl 3 with LSK170 in the forum. You can use the search function to check, look at who has built the kit with 2SK170’s or better yet ask for Wayne’s comments.
I have been working with 2SK170’s but have not gotten to the point of testing the boards. The largest question for me was the impact of a high output levels of the matched jfet’s and if the high jfet Idss in this circuit caused a change in any other parts. In my case, I am changing the R4-7 resistors from 10R to 22R to adjust for my matched set with an Idss of 8.9mA.
From what I can tell in your case, you have two matched sets of (4) LSK170’s. Depending on the differences in the Idss of the two set’s, you may need to adjust R4-7 values for each channel. As was commented in a previous reply, the matched sets should have a stated Idss written on the bag the jfet’s were shipped in or on a sticker on the jfet or measure the levels yourself.
For dual mono PSU you'll probably want two separate AC mains fuses, two separate EMI filters, two separate power transformers, and two enclosures made of ferromagnetic material such as steel. Be sure the entire stereo ensemble makes a single "star" connection to the Protective Earth terminal of the 3-wire AC mains cord.
You'll also have to own the decision (and make the decision) whether to connect the two "grounds" from the two mono channels, or to leave them independent and unconnected. And if "yes connected", at how many different positions will you connect those grounds together, and where should those connections be? At the input RCA jacks? At the output RCA jacks? From one Pearl3 circuit board "ground" to the other Pearl3 circuit board "ground"? Where on the circuit boards?
It will give you lots of opportunities to express your individuality.
