I think if you order half tube quantity for instance they cut the tube physically in half so you still have a good chance of getting similar devices. If you order 2 or 3 you might get the leftovers from the bottom of the bin.
I'll send them an email.
Thanks for the tip
C2M0280120D Looks good too
That's the part that I ordered four pieces of to compare with.
I might get half a tube of each
Buy both, assuming it's within your budgetC2M0280120D is the one I was tempted by - higher transconductance...
Cree C2M technology is so last year. Check out the next gen C3M. Its only rated at 900volts, but transconductance is 13 and Pd is 125 watts. I can't figure out what advances have been made going from C2M to C3M.
900-V SiC MOSFET | Cree Power converter
Based on the datasheet, the two cree parts mentioned need quite a lot of volts to bias up, so it may not work well as a drop-in replacement for a typical IRF240 circuit - did you you manage to bias up the transistor ?
Which cree part did you try and what was the circuit used ?
Can someone post a circuit to try the real Cree transistor.... I have 4 of them, did put some to a zen-like circuit but had lots of noise at the output... any help?
Which Cree device device do you have?
yes, gate resistor Always.You will need Vgs of somewhere between 7V and 8V.
Is that enough information to get you started?
Do you have a gate resistor?
okay thank you will try again soon
What value gate resistor?
You might need to increase it to maintain stability. You will probably need a higher value than what Nelson normally uses on IRFP240. As a guess, 3 times as large
okay i'll use 1k.
- new SiC JFETs?
