new SiC JFETs?
The 900V Cree SiC fets look like they won't be hitting distributors until October or so. Digi-Key shows Cree 1200V devices, Rohm (cheaper), ST, and Microsemi (both these vendors are pricey).
Mouser may have the Panasonic devices by now - I'll check and see.
Based on the datasheet, the two cree parts mentioned need quite a lot of volts to bias up, so it may not work well as a drop-in replacement for a typical IRF240 circuit - did you you manage to bias up the transistor ?
Which cree part did you try and what was the circuit used ?
