New DISPRE preamp, successor to previous popular version
Well, here the plots for output voltage amplitude 1Vp and 3Vp, load 470 ohm.
Federmann -
the same, 310ns time delay (at 100kHz, but not only at this frequency) has a pure RC filter built of 1kohm resistor and 320pF capacitor. The -3dB frequency of such LP filter is 500kHz.
In case you would like to offer some of your unique theories, please open your separate thread, as suggested by danhard.
Yes. There is a slight addition from input RC filter. Anyway, this 400ns does not depend neither on frequency, nor on output amplitude, up to several hundreds of kHz. Then, for frequencies of hundreds kHz and more the time delay gets shorter and shorter. The circuit behaves as a linear passive circuit. Therefore I do not understand Federmann's question. No one hears 400 nanoseconds of absolute time delay. Only channel difference in time delay would bring an audible difference, and it should be 2 microseconds or more to be audible. Again, we face a wrong assumption here.
Hello PMA,
I took a look at your Dispre2 circuit. Is there any reason why you use 2 pots in parallel on the input of your line amp? Is it for reliability? Also, I thought the input z was 20 or 22k, but it looks like 2 10k pots in parallel, so this is 5k per channel. Am I reading it right?
What are your thoughts on the Alps Blue Velvet pot? I am using a 25k on my op-amp based pre-amp - no problems so far.
These 2 pots are only in schematics. They are 2 different library components with different pin distances. Of course you make a choice of only one on PCB.
As a standard, there is a blue Alps. Those who cannot afford this pot can use 16mm cheap one, like Piher, but channel volume matching is poor then.
