With say 100p from the cable and the 7.25 resistance I'd be at about 219kHz, no?
No cable there, just a capacitance of short PCB tracks.
http://web.telecom.cz/macura/dispre3.jpg
Wow, I shouldn't do two things at once.
I can change the cap to 100p and be at 219kHz with a 25K pot. Any problems with this?
note the ~zero cable capacitance. That allows for a few pF of parasitic capacitance, since we all know that device leads and trace lengths have some capacitance to other devices/traces.There is no cable behind the pot. Please first review before you advise.
I don't need to intimately know your PCB to offer that advice.
Hum reduction
Hi Pavel,
I have completed the preamp about two months ago, without any problems.
It sounds excellent to my ears and is probably the strongest component in my audio chain.
I am using OPA2134 for dc servo.
The volume pot (Noble, 10k) is grounded, as suggested.
I am using a pretty good power supply (SuperTedyReg, can be found at Teddy Pardo home of TeddyCap TeddyXPS power supply for Naim Audio replaces HiCap and XPS) and all components are mounted on an mdf plate.
Input and output connectors a mounted isolated, on aluminum L profile. The profile is not connected to pcb ground (I have tried it connected but think this way is better).
The only issue I have is a higher degree of noise which is detectable with my ear relatively close to tweeter, comparing to my previous diy opamp preamp.
Both pairs of interconnects are of shielded type and I don't have any ground issue worth mentioning.
What could I do to further reduce the level of noise?
Thanks, Baki
Hi Pavel,
Thanks, Baki
Baki,
The power supply that Pavel supplies for the preamp is very, very good. I question if your 'teddy Reg' setup gains you anything.
Just my 2 cents. Discount at will.
Thanks, Baki
Hi Baki,
thank you for your feedback. IMO Dispre 2 has quite reasonable noise for a line level stage, though it is not a very low noise design, and it would not be enough as a microphone preamp or phono preamp.
Dispre 2 uses high value degeneration resistors in the input differential pairs. This was decided to obtain excellent slew rate and high range of input differential voltage. In fact it is impossible to dynamically saturate the input stage. The price for this decision and design is slightly higher noise. Normally it is undetectable, but it may happen that with high gain power amplifier and sensitive speakers you may hear some noise with your ear close to the tweeter.
Regards,
Hi Pavel,
LM3886 chipamp with discrete regulated supply has a high gain - 33 and the sensitivity of my speakers is around 85 db.
I thought that putting the preamp in aluminum case could contribute to a little bit lower noise.
DISPREII is excellent preamp anyway.
Thanks,
Baki
Thanks,
Baki
hi pavel
i just look at your schematic
but i cant find component values for the dc servo
can you give me the component value for the servo please?
thanks
thanks
Not in the BOM ?
(lemper + bakpao siomay is even nicer)
hahahah
u know bahasa indonesia i guess
From others. I see the designers comments on listening tests (and I think one other person.) Thanks!
I'm trying to pick a DIY (term used very loosly to mean assembly, I see in this forum DIY is more likely to reflect mad skilled designers!)
In addition to this design/kit, on the non passive side, so far for consideration I have:
a) Perander's kits
b) Starfish (seems a bit complicated for a first DIY build attempt)
c) NJ boards for existing pre
d) RelaiXed (very little info, project "dead"?)
With respect to Dispre II I'd love any ideas on:
a) replacing pot with remote resistor-shunt type attenuator
b) simple to build or have madeup case
Thanks!
a) Perander's kits
Thanks!
Very neutral and clear. Very detailed without emphasizing any FR part. A clear step up from an OPA627 that replaced. I think its close to the best a ss line pre can give you.
My build is with PMA's boards.
I am considering a new version and new PCB. 2SK170/2SJ74 input devices. More info here:
http://www.diyaudio.com/forums/vendors-bazaar/166049-dispre-ii-pcbs-available.html#post2175725
Regards,
Regards,
- Analog Line Level
- New DISPRE preamp, successor to previous popular version
