Muses Volume
Got the remainder of the headers installed on the uController board along with the proper encoder. Added the pull-up resistors on the back. The steamship is ready to test! Just need to add some temporary input/output pigtails and some LEDs so I can see what it's doing.
This is the single-ended set. Balanced set upcoming, but same additions.
Please advise which pins on X5 to connect to, the schem is a bit unclear, anode to PA2 with resistor, is that X5.5?
I can't see where installing the LED is mentioned, not even in the BOM, only in the setup instructions. Still not sure why I needed the remote, it reads as being optional.
Yes, between pin 5 of x5 and ground. Pin 3 is grounded so you can use that. If I understand correctly, you have pin 1 3 5 7 on the same side. I haven’t built mine yet but I’m pretty sure that is correct.
Hubert
I think that what Daniel mean is that the switch of your encoder is not connected.
Edit: just saw that Ripster beat me to it
Thank guys, looks like I misunderstood again. Looking at the traces on the PCB, one of the two pins is gnd, the other is directly connected to pin 3 of the encoder pins below. So I need to bridge across pins ?
A continuity test proves it - the pins are connected.
I thought Daniel included the new row of encoder pins to accommodate a single header? it should work...
I can't make sense of it - can someone look at the traces and confirm? Attached the same pic to show
Yep, tried it. Nothing again. Damn. Possibly this should have a separate discussion thread, sorry to pollute the swap meet...
But - probing pin 9 (PA2) of the MCU gives 0.2mV to the LED anode, the MCU is getting 3.25V in Ok, will take a look at the datasheet but Daniel - is there any other checks around the MCU I can make?
