MPP
I took away the 100pF at the gates of the MosFets and, voila !, it is working.
The MosFets do not like the 100pF NPO´s.
At the sweetspot of my QA400 i measure -110dB with a nice spectrum.
Most second and then 3rd, 4th and so on exponential decaying.
Under 300mV only the second at -110dB is left.
This is still the version with the lower impedance voltage devider and 270 ohm gate stopper of the BJT version.
It is also the starved version with low idle.
Raising the impedance in the bias devider and ramping up the idle i expect even better performance but it already works fine.
here....
