Or one of those little solar cells and some white LEDs
As you can see, a servo may not cancel the transient currents through the cartridge (it that's a concern, of course). Otherwise, not even a servo is required.
In fact, I believe a servo, while certainly cancelling the offset, may make the transient currents even worse.
P.S. https://linearaudio.nl/sites/linearaudio.net/files/Didden-Hawksford_Part2.pdf page 28
That's the Hawksford LFD phonoamp core. I don't think a more detailed schematic was ever published by himself (I hope I'm wrong).
All kind of implementations can be found on the net, many showing a lack of understanding of his topology advantages.
At switch off, supply caps may partly discharge through the Cart.
Hans
It can be found in the mpp thread. I believe Joachim posted it.
No, take another look.
Not easy to search for. But, found it.
https://www.diyaudio.com/forums/analogue-source/154210-mpp-145.html#post2215423
Schematic added
Some additions to the original schematic (the servo, the balancing pot) are triggering (transient) cartridge DC currents. Not a big deal, but one of the original schematic features is lost.
I measured it![]()
Please post the schematic. As I said, there are many variants flying around that are losing this feature in the process of "improving" it. One good example above.
Concerning cartridge dc concerns
On the other hand :
It is frequently claimed that pre-amps with floating supply can
by definition not inject dc into the cartridge coil.
I would love to see a formal explanation for this.
Not sure why you guys don't try using a floating power supply ..snip..
That would guarantee a zero current through the cartridge under all conditions.
On the other hand :
With or without input cap, with or without a floating power supply, with bipolars or jfets,
I believe a power on/off current pulse through the cartridge is unavoidable. ..
- Analogue Source
- Low noise Balanced MC Pre
