Low noise Balanced MC Pre
Or one of those little solar cells and some white LEDs 😀.
As you can see, a servo may not cancel the transient currents through the cartridge (it that's a concern, of course). Otherwise, not even a servo is required.
In fact, I believe a servo, while certainly cancelling the offset, may make the transient currents even worse.
P.S. https://linearaudio.nl/sites/linearaudio.net/files/Didden-Hawksford_Part2.pdf page 28
Schematic added
Concerning cartridge dc concerns
Not sure why you guys don't try using a floating power supply ..snip..
That would guarantee a zero current through the cartridge under all conditions.
On the other hand :
With or without input cap, with or without a floating power supply, with bipolars or jfets,
I believe a power on/off current pulse through the cartridge is unavoidable. ..
It is frequently claimed that pre-amps with floating supply can
by definition not inject dc into the cartridge coil.
I would love to see a formal explanation for this.
