LM1875 Amp layout
No, just at the power terminals.
Try measuring at the IC pins and see. Likely enough you're dropping a little voltage through the traces on the board.
From the spec sheet I also notice that for 8ohm loads, THD is lowest just before clipping. Does this indicate that best perfromnace is when the amp is operating just before clipping at about 20 watts?
Perhaps that most of the THD+N is noise and that is lowest (comparatively) just before clipping
I wonder if the power resisters change value significantly when hot!
power resistor
please avoid this clip to connect these 2 resistor - solder this - its safer and better contact !
chris
Might leave that for fear of shorting something 😥
yes this is very delicate ! - try to find a point as near as possible.
but in my opinion for me more then 20W is ok.
the voltage drop is because of pcb traces , any connection/solder point, speakers terminal + internal resistance of the caps (ESR/ESL) etc..
chris
power resistor
chris
Is this 4/8 ohm dummy load suitable for these chip amps?
Don't believe you can .. 2050 is NLA. For some time now
Even less likely to be genuine.
Do yourself a BIG favour simply buy a genuine lm 1875 chip form a 'Reputable' distributor .. these are ~4$.
Hardly a prohibitive price to eliminate All doubts.
The difference between 25W and 22.5W @ 8 ohms is around half a volt. Based on the measurements taken I would argue the amp is performing within specification. Why stress about it.
I retested my LM1875 kit I purchased a couple years ago. I used the parts supplied with the kit. I used my regulated supply set for +/- 25v. I scoped at the the leads of a 7.5 ohm load resistor. Output was 15.3 volts rms just before clipping or 31.2 watts. I verified the voltage with my multimeter.
John , is that performance consistent with the spec sheet ?
The plot on the data sheet shows 25w at +/- 25v which may be a worst case measurement. 15.3v rms is 21.6v peak and this is what I would expect from the amplifier with 25v rails driving an 8 ohm load. If you measured, say 20w, this would mean 7v from rail to peak which is excessive.
I haven't read every post in this thread, but check voltages and scope at the screw terminals on the amp board to be sure you are not incurring losses somewhere along the way. You may lose a couple watts due to supply ripple and output signal through the protection board and wires. At 2 amps signal current, I wouldn't expect more than a few hundred millivolts drop unless there is excessive impedance somewhere.
