New StationPi pro will have screw positions compatible with StationPi. Just hope it will suitable for your old case.
Ian
Ian
Hello Ian!
I recently made an experiment and want to share my impression.
I removed three polymer capacitors and ceramic ones from the VCCA, DVCC, AVCC power pads from the DAC board.
I installed 3 x Sanyo OS-CON 820uF. The result was found positive for sound quality. The power wires come from the bottom of each pad.
Along with the advantages, one drawback appeared. When the LiFePo4 PSU shuts down on a timer after 5 hours, I hear a loud bang and a humming decay sound. This feature appeared after the replacement of capacitors. I'm scared to burn my speakers’ tweets.
What did I do wrong and how can I fix it?
You probably only needed to do something with AVCC. Maybe best to restore the original caps for the other power rails.
I used to run 1.5F supercaps on the 3 dac rails with no adverse effects but I just had 'conventional' psu with transformer and rectifier etc. I never turned it off
https://www.digikey.com/en/products/detail/sparkfun-electronics/COM-10597/7229845What knob is that that you used on the rotary encoder?
Hi
I have problem with RPi 3b and Ian's HATs. There is Volumio installed and it is working perfectly only on RPi, but when HATs installed there is no any output. I have Isolator, 9028 DAC, DAC controller, and I/V STD board. Regulated PS is connected to Isolator board and suplly RPi and DAC, I/V board has separated regulated supply. All lights are on and controller as well. Strange thing is on controller as it after power on constantly filling the dots on the bottom and not change the image. In Volumio I've tried generic i2s dac and Hifiberry DAC+ as advised in manual. All jumpers are in default position. I do not even remember what different setting I try in Volumio with no result so if somebody has some experience please advise.
Danijel
Danijel
Does anybody happen to know the current draw of FifoPi "dirty side" (J3) when no RPi is connected?
Hi Ian, Hi everybody
I made a mistake. Changing a battery on my LifePO4 mkII, i inverted the polarity of the battery in the BT6 position (i saw some sparks but nothing more).
Now when I turn on the system i have the correct voltage on J1 and J2 (i'm using the system with 4 battery but i'm using only J1 and J2)
BUT
when I turn off the system and it goes in "charging" mode, the BT6 doesn't charge the battery.
All other 3 batteries are charged properly.
the problem is that if battery BT6 is below the threshold, the system charges the other batteries continuously without interrupting (and therefore overcharges them).
If I remove the battery BT6 (to try to use the system only with the other 3 battery, BT7, BT5 and BT2) the voltage meter on the board measures around 2V, and so again try to overcharge the battery.
I suppose I burned something but I don't know what.
Can you suggest me something to control or to change on the board ?
There is another way to avoid using the BT6 battery ?
Thanks in advance
Paolo
BUT
Thanks in advance
Paolo
Hi all
Waiting for a support may i suggest a crazy idea? Considering i'm using only two output on the lifepo4 (j1 and j2), to avoid the recharging problem may i put the battery in BT5 position connected in parallel with the BT6?
In this way when the system is ON on j1 i have two battery connected in parallel.
During the recharge phase both battery are recharged via BT5
I don't have the electric schema of the board and so i'm not sure to make a good thing or i will destroy everything
Hoping someone can answer me i salute you
Paolo
Paolo
Is there anyway I can get this special order? 957 @ 90/98Mhz
Both the NDK SDA series and Crystek CCHD957 are available in those frequencies but only to special order.
Ian has had some, or tried some but I don't know which brand.
I used to run three 1.5f caps as in the image above i never had any bang. In fact they just faded to silence over 30 sends or so once turned off.
Just got one of the Bisesik transformers.
I’d like to try it running from Intel MB or direct USB, rather than RaspberryPi - what hats should I get?
What alternative to Pi are you going to use? I'm interested in trying an alternative to my Pi 3 and just got sent this which looks interesting:
https://up-board.org/up/specificati...196460089&mc_cid=412962af29&mc_eid=a1cdecbfed
Yeah, mines a classic ATX Intel MB I've like to connect to... I'm getting USB out is probably the way forward.What alternative to Pi are you going to use? I'm interested in trying an alternative to my Pi 3 and just got sent this which looks interesting:
That's a nice Intel based Pi board however.
I'm finishing up my V3 of my Ian's DAC stack. I'm using the standard clocks that come installed on the FiFoPiQ3 and want to install some better ones. The FiFoP1 user guide recommends the Crystek and NDK clocks as ones to consider. What's the current state of clocks like we use in our DAC stacks? Have any better ones become available since late 2020 when I was building my original V2 version? Or, should I just stick to the recommended ones.
Crystek or NDK are a good upgrade. The difference between the two maybe subjective.
After that you're probably looking at an Andrea Mori product which even having sampled the entry level clock, does give a noticeable improvement. All in my ears of course!
Doede did a very good review of a few clocks. If you have not seen it, it is a good overview.
In addition to Crystek which are similar to NDK he also covers Accusilicon which looks interesting. They are easy to use like Crystek but likely a step up. I also think Andre's first generation Driscol is a great compromise if you can find one. If you build it without the oven, it can deliver 80% of the sound without a requiring a bulky enclosure. While I am happy with Andrea's latest and greatest, I think Accusilicon is a great choice. The stock clock supplied with Fifo is only for testing. For me, NDK was a big step up from that.
His blog is http://blog.dddac.com/the-clock-tests-part-3/
Thanks guys. I think I'll go with the Crysteks. I prefer the easiest to install. I've found the 2 I need at Digi-Key, but now it appears they need a small PCB to fit the 4-pins needed on the FiFoPi board. Their SMD pads are underneath. Is there a link to the type of breakout board I will need, or a part number? I can solder SMDs provided they're not the very tiny little suckers. 🙂 I haven't looked at the Accusilicon yet, but are they an easy drop-in replacement that would fit the FiFoPi w/o an adapte?
- PC Based
- IanCanada's Latest RPi GB Goodies Impressions... and your tweaks, mods and hints...
