Sharp XR10X
I have a Sharp XR10X projector. The lamp has went bad on it and I was shocked at what they are charging for replacements. ANXR10LP is the case and bulb part number.
I started to look the unit over and wondered if just the bulb itself could be replaced.
I came accross this message board and found this topic being discussed at length.
I tried to find a part number on the bulb itself, but it must be where it is broken. It looks like it could be an easy fix to just change the bulb, but wondering what the cost and if the right bulb is available.
Please help!
Thanks, John
BTW, Your discussion here is very interesting!
Please help!
Thanks, John
looking for lamp for proxima dp5800
Hi ywh,
I'm looking for a lamp for my proxima dp5800. Its manual says the lamp is 260W Metal Halide.
After going through this long thread
, I found that user pfloydphan has ever ordered one from you. It seams a DC lamp and very similar with the picture you posted before (attached in this post) .
I don't know if you still have it in hand and am very appreciated your responding.
Thanks a lot,
supwang
Hi ywh,
Thanks a lot,
supwang
I know the lamp is 260W Metal Halide DC, but some this type lamp is run in 40v about.
most are 60~80v, they can not run in 40v ballast.
so you have to test the V
ywh said:I know the lamp is 260W Metal Halide DC, but some this type lamp is run in 40v about.
Hi ywh,
How can I test the Voltage?
I currently can't power on my projector properly.
With lamp installed, its temp led will blink red and projector will go into standby mode. From its manual, this seems to be a fan problem. But I doubt it, because when I power on, the fan will run 1 or 2 seconds and then stop.
Without lamp installed, its lamp led will blink red and projector will also go into standby mode. I tried to test the voltage of two pins which are supposed to connect to the lamp, but I got 0 for output.
Thanks.
YWH: You told me to pay 18Wheeler. What is his email address, or paypal address? I went to the DIYpro website and that address does not work. I wrote to it 3 times with no response.
I cannot email anybody directly from this forum yet. I guess the forum moderators think everyone is an expert and must answer 400 questions a month.
-Stampee
-Stampee
Hi supwang!
there is a switch, if you open lightbox's door, it will power off, you have to keep it power on, check it, lock the switch.
Hi stampee
diyproj@gmail.com
Hi stampee
diyproj@gmail.com
Lamp for Infocus LP350
Hi YWH,
I'm looking for a lamp for LP350, its DC SHP 270W, mine blew out and dameged the reflector. Could you help out? I saw someone who got help from you -JYC270. I'm in Chandler, US, I would probably need 2...
Hi YWH,
Hi vpredtec !
dont bother the crack, it can be used,
be careful in remove the ceramic cover, you can break ceramic cover, but have to catch the ceramic holder, dont break the cement between glass and ceramic holder.
YWH or Fly2max: I have the Infocus LP350. Can either of you confirm if this is a single ended or double ended bulb? I definatly see wires going to both ends of the bulb, but 18wheeler says I should also see a screw at each end which I do not have.
Any advice on the proper bulb would help.
YWH previously told me I need a JYS dc 270W but in single or double ended mode?
Thank you
-Stampee
Thank you
-Stampee
lp340b
i'm about to crack open a broken lp340b. what should i look for to determine an upgraded power supply or not which currently works.
feedback needed
To all who have order ywh's lamp
Can any of you provide and details of how you centered your lamp and how has the brightness/longevity been using these lamps?
victor
victor
ywh: I have a Canon Projector LV-S1 that takes a 150 Watt UHP. Do you have anything fitting? Thanks
I searched the threads, but could not find any instructions for installing with the cement. Is there any?
ywh said:Hi supwang!
Hi ywh,
It's 40V DC lamp (260w). How can I buy it from you? Through moneybookers?
Thanks.
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
