How would you drive an EL509 in enhanced triode mode.
Please discribe what your (or his ) view of "enhanced mode" is.
I never use "enhanced mode" i use "triode" mode with G1 shorted to C. This is not Tim's version but David's version (please see patent).
I have build a couple of amps with great results (most of them beeing PP amps btw with 600V B+ or higher and DC feedback for high stability).
Then the next question: How is the grid driven? If the tube is not driven with a low impedant source it will add to the distortion (but i think you already know this).
Best wishes,
Frank
I was looking at Bob Danielak's amp, screen driven output tube, with cathode bias and G1 to gnd.
He drives that screen directly from a cathode follower, no resistor involved. I have seen another example with several 100 ohms series R between cathode follower and screen, and complaints of high distortion.
BTW What is the sensitivity of screen drive, is it higher or lower than grid drive?
Jan
Bob Danielak is actually using a standard grid modulator (as can be see in RF transmitters).
This will even need more current as G2 is on a higher voltage and therefore attracts electrons.
In triode or enhanced mode it also needs a higher voltage swing but is more linear as the voltage on G2 is much lower (near 0 V). Because of the higher voltage swing you will need a better buffer/driver...
No resitors on G2 as you like curent to flow if needed....
Hi Bas,
just to complement. changing the pot changes the current through the driver tube. This changes the voltage drop over the plate resistor and therefore at the drivers plate. This changes the voltage at the CF's grid, consequently at it's cathode, and so the voltage at the G2 of the output tube.
Good luck with the build!
erik
Reactions: Bas Horneman
It's alive and playing in my testsystem (Mission 753 and Chromecast with Spotify). So far so good. No explosions...Will keep you updated.
