Hi-end 845 with only two stage
LL1668/25mA 100H arrived and tested!
Here the final frequency response.
only -1db at 20Hz with 10Vrms on 8ohm
This is a very very good result.
Soon the sonic performance test with 2 channels.
Here photos of the stereo test environment in a sonic performance test with Tango output transf. and the final driver circuit with Lundahl 100H.
http://www.audiodesignguide.com/Claudio845/photoAll1a.jpg
and a beatiful night view
http://www.audiodesignguide.com/Claudio845/photoBlue1a.jpg
Using only two simple resistors on catode and ac filaments I ear no noise on the my Monitor 2 and Martin Logan Aerius loudspeakers.
Probably if you have high efficiency loudspeakers it is necessary a use dc filaments or a simple trimmer on cathode.
The power is enough to drive any 88-90db loudspeakers.
The sound depend in great part by the interstage capacitor.
Rod,
In any case I prefer the sound of the new 845 v2 but this only my opinion.
I don't see real solutions to have a Jensen copper film like interstage in this design with 6HV5A.
Probably a solution could be use the Bartolucci interstage transf. INT7 with 100H.
I am waiting on the first days of January both the interstage transformers, Lundahl and Bartolucci.
So soon I will update this Forum with new test.
It is sure that the first LC solution with not the best and in many case the interstage + inductance cost is quite equal to a good interstage.
Sorry, These is an error in the schematic, the interstage transformer should be the LL1692A and not the LL1689
LL1692A/18mA have these characteristics in ALT_S connection:
125H at 4:3.5
max out 175Vrms
I will ask to Ludahl about the insulation rating.
Generally, Ra of a pentode run in triode mode is much less than the pentode Ra. Possibly the Ra is ~ 1000 ohms or less so IT's with less than 100 H should work. The pentode Ra of the 6HV5A is 4600.
I'm no engineer so please correct me.
There can be no pentode mode of a 6HV5 since it only has one grid. It is a true physical triode. It has added beam forming plates that prevent the electron stream from irradiating parts of the inner tube structure and anode by statically fixed physical shadowing.
Someone please correct me if I am mistaken.
I have found a problem in the first release using LL1668.
If the core/chassie of the LL1668 is connected to the ground of the amplifier there is an isolation problem and frequency response is compromised at 12KHz.
I have spoken with Lundahl about the LL1668 problem.
It is not an isulation problem, the Lundahl product can work until 1500V without problem.
It depend by the parasite capacitor so It can be resolved with a simple separation of the LL1668 and the chassie ground.
Follows the new frequency response of the last LC version using Ll1668 and Mundorf 2.2uF.
I will test soon the interstage transformers Lundahl LL1692A and Bartolucci.
Andrea
You used to play with OTLs some time ago and you got a lot of us hooked up on them. Now you seems to concentrate on high voltage single ended designs. Do you get more out of these designs than OTL? I am really interested to know what your sonic results are in comparison with all these designs....
