HermesBBB-Cronus-Opus
I am taking more pictures
Make sure MPD is actually listening on your network interface(s). By default it will not (only localhost)
Check /etc/mpd.conf for the line with
Code:
#bind_to_address           "any"
Change to (ie uncomment):
Code:
Hmm. I tried this and it still won't play nice.
In default connection settings, I've tried using the default settings and also entering the IP address of the BBB. Neither one works. 😡
root@botic:~# squeezelite -l
Output devices:
null - Discard all samples (playback) or generate zero samples (capture)
default:CARD=Botic - Botic, - Default Audio Device
sysdefault:CARD=Botic - Botic, - Default Audio Device
dmix:CARD=Botic,DEV=0 - Botic, - Direct sample mixing device
dsnoop:CARD=Botic,DEV=0 - Botic, - Direct sample snooping device
hw:CARD=Botic,DEV=0 - Botic, - Direct hardware device without any conversions
plughw:CARD=Botic,DEV=0 - Botic, - Hardware device with all software conversions
default:CARD=Pro - Music Streamer Pro, USB Audio - Default Audio Device
sysdefault:CARD=Pro - Music Streamer Pro, USB Audio - Default Audio Device
front:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - Front speakers
surround40:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - 4.0 Surround output to Front and Rear speakers
surround41:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - 4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - 5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - 5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - 7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - Direct sample mixing device
dsnoop:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - Direct sample snooping device
hw:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - Direct hardware device without any conversions
plughw:CARD=Pro,DEV=0 - Music Streamer Pro, USB Audio - Hardware device with all software conversions
Now there is white noise coming out ...better than nothing...
/sys/module/snd_soc_botic/parameters/ext_masterclk=9
/sys/module/snd_soc_botic/parameters/dai_format 16385
in uEnv.txt
optargs=snd_soc_botic.ext_masterclk=9 snd_soc_botic.serconfig=MMMM
