You can check if MPD is listening with:Hmm. I tried this and it still won't play nice.
In default connection settings, I've tried using the default settings and also entering the IP address of the BBB. Neither one works. 😡
Code:
kramer@beaglebone:~$ sudo netstat -lptv
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 *:sunrpc *:* LISTEN 983/rpcbind
tcp 0 0 *:32821 *:* LISTEN 994/rpc.statd
tcp 0 0 *:ssh *:* LISTEN 1017/sshd
tcp6 0 0 [::]:6600 [::]:* LISTEN 1012/mpd
tcp6 0 0 [::]:sunrpc [::]:* LISTEN 983/rpcbind
tcp6 0 0 [::]:ssh [::]:* LISTEN 1017/sshd
tcp6 0 0 [::]:56218 [::]:* LISTEN 994/rpc.statd
or
Code:
kramer@beaglebone:~$ sudo netstat -lptv|grep 6600
Or check with mpc on the BBB itself:
Code:
kramer@beaglebone:~$ mpc -h localhost
volume:100% repeat: off random: on single: off consume: on
Voltages from pins
BCK 1.65V
MCK 0.002
D1 1.65V
D2 1.65V
MCK shall not be zero - check soldering on the MCK connector - also shorts to ground. Other seems to be good.
I checked nothing obvious ,more over I have two sets of pins now in B3 and B3SE slots.
If I have only one Crystal does it need to be in X1 or it does not matter?
for just experimenting I put 45.1584/49.152MHz pair in place and changed jumper to 1:2 and tried
root@botic:~# play -V3 -r 44100 -c 1 -b 32 -n -c 2 synth sin 1000 vol 0dB
play: SoX v14.4.1
Input File : '' (null)
Channels : 1
Sample Rate : 44100
Precision : 32-bit
Endian Type : little
Reverse Nibbles: no
Reverse Bits : no
Output File : 'default' (alsa)
Channels : 2
Sample Rate : 44100
Precision : 32-bit
Sample Encoding: 32-bit Signed Integer PCM
Reverse Nibbles: no
Reverse Bits : no
play INFO vol: has no effect in this configuration
play INFO sox: effects chain: input 44100Hz 1 channels
play INFO sox: effects chain: synth 44100Hz 1 channels
play INFO sox: effects chain: channels 44100Hz 2 channels
play INFO sox: effects chain: output 44100Hz 2 channels
In:0.00% 00:00:00.00 [00:00:00.00] Out:0 [ | ] Clip:0 play WARN alsa: Input/output error
play FAIL sox: `default' Device or resource busy: Operation not permitted
Done.
play: SoX v14.4.1
Channels : 1
Sample Rate : 44100
Precision : 32-bit
Reverse Nibbles: no
Reverse Bits : no
Channels : 2
Sample Rate : 44100
Precision : 32-bit
Reverse Nibbles: no
Reverse Bits : no
Done.
Is a squeezelite running on your BBB? if yes, you need to stop it first, because it has audio opened exclusively.
kinku: please try P1:4 jumper and then also P1:1 jumper on clock divider. It will play faster, but at least you will check that it works.
(( I have P1:2 broken on my Cronus - it does not work at all )
Oh my God Lord !!! you are right Miero,now there is sound distorted and slow on 1:4 and 1:2
Mine was on 1:1 with 22Mhz crystal..
On your Opus, set the OSR switch to low (-). This will set it to operate with 44.1K sources.
Brian I tried that ,no sound out. Twluke using with OSR at mid position without any issues.
What can do now, it seems like a hardware issue at this point?
That means you divider is working fine. Miero has a different issue (his module is a prototype)
One other note - since you share common power supply with he Opus you need only have the power supply GND you don't need the additional GND wire.
Also - on the opus you must observe correct power on sequence. Try powering it from single 6V supply.
Yes it needs to be in X1
It seems as if you may have a shorted master clock?
Can you please explain a bit more? What is the fix ?
Miero suggested to change the jumper and there is sound distorted and slow.
What is the correct power on sequence?
Both VA and VD most come up together - this can be hard to guarantee with split supplies.
Yes - the fact that things changed to slow when you added the jumper indicate that the divider is working. Also the BBB was playing which means it was getting a good master clock. That suggests an open cct somewhere.
Please try the single supply and single ground wire from cronus to opus.
Russ both power circuits are using two secondaries of a single transformer. Will the delay be significant in this situation?
You are suggesting that I may not need the green cable between Cronus and opus ,if I am powering both from same digital supply.
I am now trying to power digital and analog part of opus from 6 v supply , and use salas to power Cronus only . And will keep the green cable for this configuration. Will be back in 5-10 minutes.
- More Vendors...
- Twisted Pear
- HermesBBB-Cronus-Opus
