First Watt SIT5
Yes, but I don't know whether the higher transconductance of the puck is advantageous in this situation. It seems to me that since we want to limit the contribution of the mosfet, the lower transconductance may be welcomed. In any case I do not need the dissipation capacity of the puck.
Just to finish it off, the signal peak to peak current through R10 was 450mA, from mosfet toward SIT. Current at SIT drain was 274mA. Adding the two is 724mA, which is close to the 719mA through C4.
So the currents seem to sum up properly. From what I can see, output signal from the mosfet exits through C7 and C4.
That's my amateur DIYer's perception - may or may not be the truth. 🤓
I have been thinking of a simple way to bias the mosfet.
If you have hundreds of SITs to choose from, maybe you can find SITs that have a high Vgs, higher than the Vgs of the mosfet plus the voltage difference between the SIT and mosfet sources.
I don't have hundreds of SITs though. 🤓
Here is something to think about:
The image shows a sequence of equivalent circuit transformations of the SIT5 Output Stage. The sequence is ordered left-to-right, top-to-bottom. Simulations verify the correctness of these equivalent circuits.
Reactions: schultzsch
There should have been one more final transformation replacing the battery -z0 with the output capacitor.
For biasing purposes, the original schematic makes sense, but as a result of this analysis, I do not understand the importance of Papa's "ratio R1 and R2" statement".
