diyAudio Power Supply Circuit Board v3 illustrated build guide
Input snubber
Sorry, newbie question coming:😱
1)
2) The input snubber is something worth doing. (Ignore the output snubber. ) Because you are using the AS-4218, I know that the values of 0.01uF+12ohm and 0.15uF work well.
I am thinking about using the Toroidy Audio Grade 400VA 2 x 18V. Does someone know the values for the input snubber (or can me help to interpret what I have found)?
500VA is said to be Cx: 10nF, Cs: 150nF, Rs: 7Ω / 7Ω. (On this list.) I can't use that for the 400VA, correct?
Someone measured it in this discussion, but I'm struggling to understand which value to use practically.
For a class AB amp, do you think dual mono is better than 2x capacitance shared? Or does it depend on the magnitude of the capacitance being doubled?
For example, on a 150W @ 8 Ohms amplifier, would you rather have 20mF per rail per channel or 40mF per rail shared by both channels?
Just saw this.
No. Don't do that. One thermistor in series with the AC primary only.
The other CL-60 goes on the output of GND at the power supply.
lWATrYKXMnng1VQN.huge
GYDPdQEG6POwfpUY.huge
6L6
The wires that run to and from the PS board appear to be a fairly large gauge, what gauge is best for that application?
I'm not normally much of a video watcher, but that Indian amplifier PSU build was great. I get far too precious with stuff whereas he just gets on with it.
BTW, aren't the DIYA Store boards scored? Can't you just snap off the diode section?
Exactly! I ordered power supply boards twice over the past year-and-a-half and both times they were snapped apart, courtesy of the US Postal Service. I hope the diyAudio store has found a better way of packaging other than in lightly padded envelopes which are easily folded to stuff into a mailbox.
