diyAB Amp The "Honey Badger" build thread
the small ccs is touching the heatsink and is quite some distance away from the input ltp, so that is also a probable reason, decouple stray capacitance and add stability...
Hi Tony, why does the heatsink matter regarding R14? I did not follow. Also what heatsink is being referred to here, the OPS heatsink?
Regarding the CCS stray capacitance, it does not matter much for stability. In a diff-pair (or LTP) the node where the current source feeds the pair is small signal ground for differential mode.
In common mode, the cap does play a part resulting in 2nd order distortion at higher frequencies, but usually well beyond the audio range.
Finally, let's think numbers. If the stray cap at the node was 10p, the time constant with 2.2k would be 7.24MHz, to high to matter. Even if was 30p, that would still be 2.4MHz.
if you built this amp, there is a small heatsink where the VAS, the big CCS, small ccs are mounted, this is the heatsink i was reffering to, not the big heatsinks where the power output devices are mounted..
you do not have to convince me, not my idea anyway, i just gave a plausible reason....instabilities in the mhz region can happen more than we know...
that is why the base stoppers...strays in the 30pf are not uncommon...
HoneyBadger Oscillating Under Load
I built two honeybadgers same components as in the schematic just some of the transistors are higher hfe grade, it would oscillate at 400KHz on the top of the waveform if I played a sign wave at 50 watts or higher this was into a 8 ohm subwoofer, I Got it to stop by putting two 220pF caps across the two 47pF's next to the driver transistors I also removed the LC cap and C6 as suggested in the forum it has less ringing after removing those parts, I would like to make sure my modifications are okay and not ruining the transient response or some other unknown thanks for the help.
can you have it marked as your as built drwing for the benefit of others.....i guess for subwoofer duties, you need not have such a wide bandwidth...
what was your turn over frequency for your sub?
Got it... I have not built it, so I did not know the CCS had its own heaksink.
this is a modern day design and really delivered the goods....
i built a multi pair version with SOA limiting circuit...
Hi Tony, while I have not built the HB, I am well acquainted with the design and spent quite some time with it on LTSpice. Ozz was kind enough to provide a .asc for me to use. I guess the .asc does not say where heatsinks are.
Actually, I am using the HB as the baseline for my current project, the SW-VFA-01. As part of the of the design, I started an educational Youtube video channel where I share my knowledge on audio amplifier circuit design. The structure of the videos kinda follow the Cordell and Self books, but they have my own spin to things.
You can find the channel here:
SWAudio
The link is also on my signature below.
Thanks for all the info,
SandroHV
