There should be a connection to both fastons near 0V test point. One to speaker ground one to PSU ground
For the record, it was the missing bridge for C1. I ran over the board checking all of the jumpers but I didn't notice the jumper for the large cap, underneath my large cap 🙂
Thanks for all the help guys, i've been looking forward to this!
One board solved, my second board had the same problem with the missing jumper for the large cap. The problem is during my testing TP1/2 the TP2 lead fell out and shorted out on the board.
At the time, both fuses and R53/54 burned. I've just replaced the resistors and put resistors in for the fuses. On power up, R53 burned immediately. IVe gone over the board searching for anything that looks like it may have been damaged but visual inspection is OK. I tested all resistors and they look good. I've tested the diodes and D5 is bad, it does not conduct either way.
If D5 was bad, would that account for the burning of R53?
It looks like Q19 fried. I don't have an HFE tester but I was getting continuity across pins on Q19/20/21. I pulled Q19 and Q20/21 on the board are no longer shorting out. Q19 has continuity across all pins now that its out of the board. Looks like i'll need to order a couple of parts!
yes, you better get all defectives replaced, and use a light bulb in series with the line so that in case of mistakes, the consequences are not so pain-full...
Will the circuit perform fine with a significantly lower gain? My input signal is ~3VRMS so I would only really need less than 1/3 of the gain that the amp provides by default. Obviously there is no point in me having a voltage gain of ~40.
What is the ideal way to change this circuit in order to reduce the overall voltage gain?
441 discusses emitter resistors. They do not affect audio gain.
Are you referring to post 790? That's where OS told me:
Either way will work.
Play around with the TMC feedback resistor.
It is shown as R24 (820R) ... 1k ,1.2k, 1.5k will slightly reduce
LG at high frequencies. I will order 1.2k for mine.
820r also will show (minor) ringing on clip/squarewave.
This is the resistor that makes the HB "too accurate" .
OS
__________________
Mongrel website , always current and updated :
Start! Fetch!
you can increase the value of the shunt resistor in the feedback loop, R5 which is 820 ohms can be increased to say 1200 ohms to lower gain....
I'm using 820 and 24k in nfb. In TPC I have 1.2k and 82pF and 390pF. In simulation it looks good. The first board is almost complete. Now, it's time to build the case with PS and then plug it in. Then I'll see if it works and hopefully be happy with results
cheers,
cheers,
Sorry if I gave you confusing advice. I went from memory to a post where OS had tried to help me. I didn't change mine since I use a Mezmorize B1 and it is unity gain.
Blessings, Terry
Blessings, Terry
no need to apologize Terry.....
the original super Leach from the Audio Magazine, used a gain of X19....
many professional amps used gains of x30 to x40....
and yes, depending on your source, a higher gain can be usefull....
Yes, my Super Leach is definitely lower gain. On my A/B set up, I have to crank the volume knob quite a bit more for the Leach to attain an even volume level with the HB.
Good news, bad news!
The side that didn't spark is working great! The side that sparked and damaged Q19 and D5 has a lot of hum when powered up and when playing music sounds like the highs are muffled out.
Before I go and buy an HFE tester, does this sound like a specific issue? I'm thinking a few more transistors probably blew out and instead of a tester I may be better off just buying a new set (minus Q19).
The humming was user error, after assembling the chassis and taking readings from the speaker terminals, I got -30mv on the noising side! I had a hard time adjusting that earlier, the mv would creep around a lot. Now both sides are down to 0.1-2mv and holding steady.
R14 is measuring 8.44v on both sides and TP1/2 measured around 30mv. I'm going to let the amp warm up for a while before taking readings again.
Right now, the side with the issue still sounds a bit muffled/muted on the high end. I could do a REW measurement if that would narrow down the problem, otherwise I may just end up ordering a new set of transistors from digikey.
- diyAB Amp The "Honey Badger" build thread
