Play around with the TMC feedback resistor.
It is shown as R24 (820R) ... 1k ,1.2k, 1.5k will slightly reduce
LG at high frequencies. I will order 1.2k for mine.
820r also will show (minor) ringing on clip/squarewave.
This is the resistor that makes the HB "too accurate" .
OS
Mongrel website , always current and updated :
Start! Fetch!
Will the circuit perform fine with a significantly lower gain? My input signal is ~3VRMS so I would only really need less than 1/3 of the gain that the amp provides by default. Obviously there is no point in me having a voltage gain of ~40.
What is the ideal way to change this circuit in order to reduce the overall voltage gain?
Good news, bad news!
The side that didn't spark is working great! The side that sparked and damaged Q19 and D5 has a lot of hum when powered up and when playing music sounds like the highs are muffled out.
Before I go and buy an HFE tester, does this sound like a specific issue? I'm thinking a few more transistors probably blew out and instead of a tester I may be better off just buying a new set (minus Q19).
