Congratulations to the winners of round 2!
.. and welcome to a new batch of Fearless Amp Builders. 😉
My day started off with news that will end up being somewhat bad, bad or terrible depending on results and then just at the right moment I decided to check here for interesting posts as a diversion. Now I'm on the winners list!
Congrats to the winners and welcome on board!
Excellent little amp, you won't regret it, and is also a beauty
Enjoy music
Claude
Enjoy music
Claude
Have the schematics and chassis wiring guides been published for the N VFET version yet? Or a list of deltas from the P version? Been looking for them but have not found them.
Thanks in advance.
Thanks in advance.
LOL! The heat sink is the same for the 4650, 5650 and one channel of the 8550. The 8550 puts out 100w per channel, but measures at 125w. So, it's over-rated for the 4650. It's a good chunk of heavy aluminum. The one in there is actually from an 8650, rated at 80W per heat sink. It will be tested in due course.
Oddly enough, somebody in the day measured the 4650 and found that it put out 60 watts RMS at one percent THD, so it was also conservatively rated. I think the 5650 also was measured almost to 80w/ch RMS.
The TA-5650 heatsink is slightly larger with space for 8 sk/sj the 4650 and 8650 share the same heatsink (2 off in the 8650 for 12 transistors).
I have a spare 4650 HS and a fully working 4650 pre-amp vfet stage, so am very interested to see what you are doing with your build. I have a couple of spare 2SK60s that I could use in a roll your own design.
Any more details on the amps and voltage doubler would be appreciated. Maybe move to a new thread “V-Fet round3 roll your own”
Hi, jonboylaw. Yes. As soon as I win either another board lottery, or NP and the store release the boards for 2SK60 (or SKJ18), I will be using the 4650 chassis for the build. The small 1 amp 20V SMPS powers the preamp fine and sounds great, no discernible noise. I have a small voltage booster attached to it, and that so far also powers the 100v phono stage. It needs shielding, however, it hums, and I am figuring that out now. So far aluminum foil shields it.
I will include pix as I go along. I will have a second 36v (??) SMPS that will fit internally for the amp stages.
The second SMPS should fit fine inside the chassis @75w/channel for the 10 (??) watts class A or so per channel.
This is only my second DIY after the Korg preamp, so it is a learning process as proceeding.
nope
around New Year
I was hoping for a bit earlier since the units are shipping now and I expect mine by the end of the week. Even the schematic would suffice for now, with the wiring diagram being a help. Not looking for a full blown build guide.
Thanks.
I believe the updated N-type documentation will be available before New Year. ZM is a Wiley one.
Yes, I remember from The Pumpkin and The Shunty days. Still have the boards and all the parts to build them. Just need the time.
In a personal reply from Nelson, he stated a few days ago that he had to finish one item, then the N type VFET documentation will be published here - so probably not long now.
That was
That was evil , hilarious, and awesome all at once. If Zen were near by .... I would buy him a beer or two for that...
Bravo!
Bravo!
- DIY Sony VFET Builders thread
