I think I found the answer for better or worse: clip out one RIAA feedback cap and substitute the other cap with a variable potentiometer in order to adjust gain down by lowering overall feedback resistance. That should allow gain to be dropped to 10-20db range by adjusting the potentiometer. I guess the value of the potentiometer is the question.
I might try it since I don't use this phono anyway. It would produce a flat ?? small signal VFET gain stage (linearity unknown).
Well, it's worth farting around with since it is there and demands to be abused. Possibly useful as a VFET head amp for MC cartridge to feed a more robust RIAA stage, if it turns out to be quiet enough.
I'll stop polluting the thread now.
The "round 2" VFET lottery entry window has been announced (it's in about 40 hours from now):
DIY Sony VFET lottery discussion
VFET-less round 3 details will come once the dust has settled from round 2.
Thanks for including a few UTC-to-local time conversions. It's a welcome reminder to check and double check: on MY clock in MY city, when will those magical 15 minutes occur?
Well, it's worth farting around...
Farting around is what we do best.
here we go again!
good luck to all of you
I guess I will try entering the piranha infested waters of the feeding frenzy to see if I luck out, if I don't forget tomorrow. If no win, the future hot rods for 2SK60/J18 will be next.
+ 1 useful for Diyers who wants winn the kit 🙂 Thanks to thing about..
Just as a point of follow up, I energized the phono section of the TA4650 and snipped the capacitors in the feedback circuit. Didn't blow up.small signal gain stage, yes
there is simply not enough juice for anything more
Listening through a cell phone half turned up with music and keeping the volume of the main preamp at below 10 o'clock, the RIAA indeed turned back into a flat amp with a good bit of gain.
I connected the hi sensitivity headphones to the main preamp outputs so it was nonRIAA small signal VFET>4650 preamp section>headphones.
Surprisingly as long as it was kept within bounds, the sound was wonderful. Baby VFET in fact sounds like you put a little extra tube in there. I will isolate the outputs to bypass the preamp later and see how it works as a head amp for an MC cartridge fed into another RIAA MM phono amp.
Luck Go all
Sometimes my wife Quotes the
The VFET lottery entry thread is now open, and email on the server has been disabled for 5 minutes or until any server load issues settle down.
- DIY Sony VFET Builders thread
