DIY biamp 6-24 crossover
I would like to add a volume pot and a buffer in front of my 6/24 xover.
Is this sketch correct, will it work?
Here is my completed 6-24 active crossover in an integrated line stage. BA2018 line stage with Salas I-select input with Academy Audio VCU Muse volume control. The power supply is remote with a VRDN set to +18 -18vdc and a Meanwell hospital grade 24v SMPS with an SMPS filter in the power supply housing and another under the 6-24 PCB. Both power supplies have voltage adjustments, which I set under load. There is a +15 -15vdc regulator for the I-selec, VCU and Mute relay. The 6-24 has 24 postion 50K pots for low and high level, it uses 2SK170BL JFETs for the buffers. I used 6 matched pairs where the matching is left and right channels. I raised the 6-24 PCB and made a clear plexiglass cover with holes for the 6-24 adjusting pots.
with this sophisticated build, i can only suggest to replace smps with linear supply like Salas BiB
Here with a better drawing again my questions:
1. can I add for overall volume control an additional frontend to the existing front end (marked with yellow marker)?
2. can I remove the coupling caps and the connections to VREF in the existing front-ends (red circles)?
Thanks for your feedback.
