A guide to building the Pass F4 amplifier
I know you remember. You don’t forget anything! Even your own birth is probably fresh in memory. I was thinking about the other guys in here. I know I have poor judgment, but I don’t want people to believe I am bat**** crazy. Or maybe I am? I really don’t know!
then you either didn't read or understood what I wrote in #2623
it could save you of massive search
Zen Mod,
What I was trying to say is that I did my own research when one of the pots wasn't giving any result and from that effort I determined I had reversed the pots. I'm fine with doing my homework and this time it paid off.
But then when I still wasn't getting any juice, I reached out and Dennis offered up I had the wrong resister in R9.
But I also will admit I didn't understand Iq when you referenced it in 2623. But now I do given the postings since then.
So thanks all round.
what matters is that you made it
my remark is just regarding need of patience and careful reading of replies, when question is asked - it could be case of proper reply given but not seen
I'm not picky/vane (even if Omnihighheaded) :clown: regarding many things, including effort I made in typing few lines, so no apology nor special thanks needed
Ok. New Problem. My left channel won't bias. I've turned P1 all the way in each direction, but no heat. P2 works.
From research it could be one of many things:
1. TL431 [post 2144 & 2161]
2. Polarity of Mosfets [post 1200]
3. Soldering of source resistors [post 1200]
4. Shorts under keratherm [post 1200]
5. try 6.8K or 5.6K at R9 instead of 10K [post 1507]
6. Try 47.5k at R8 instead of 47.5K [post 1523]
I tested the Tl431 before installing. I"m using either TL431BQLPR or TL431AIZT
I started with the Variac to test for shorts, none seen
I checked the left board against the right circuit board which biased just fine.
I checked for shorts on the Mosfets, nada
I guess I'll swap out the TL431 first, then make resistor change at R9.
Any other thoughts? Thanks
Not saying it's the problem, but if you want the same TL431's that I use (ON Semi, 40 uA minimum cathode current), send me a PM and I can mail you some. But, assuming properly installed parts, adequate soldering, isolated mosfets, etc. You need ~4 volts from G to S to get these output devices woke up. I built my boards with a 5K at R9.
All Good
I started today by measuring between N - P voltage, 2.3 V still no heat.
I swiped out R9 for a 5K resistor. Still no heat.
I swapped out the TL431.
This time plenty of heat, but I couldn't control the biasing, P1 was all the way out.
So I replaced the R9 with a 10K.
This time everything worked.
I've held at 190 mV for two hours.
I'm not sure what was the issue. I did use a TL431BQLPR TL431 instead of the TL431AIZT.
So it goes.
Here's a question:
I just noticed that my right channel biasing readings are:
Bias .176
Offset: -.001
Left channel
Bias .173
Offset: .002
Shouldn't the bias reading show negative like the offset does?
DC readings are:
Right: - 21.96
Left: 22.01
I'm looking for a misconnected wire and appreciate any thoughts.
Several days later
After several days listening [sounds sublime] and the amp running 8 hours a day, today I noticed the right channel was louder and the balance was way off, favoring the right side - really annoying.
My measurements:
Bias Offset heatsink temp
Left 190 0 42 C
Right 190 0 52C
I lowered the right bias to 160 and the temp only lowered to 49C.
Something seems amiss - one of the Mosfets not working properly?
check for uniformity:
-torque of mosfet screws
-voltage at/across all source resistors
re-check all solder joints
F4 is damn follower, if you have lower output - it's either problem with pre (swap channels test) or trivial problem with interconnects/contacts or ......... Gremlins
temperature issue - hope it'll be clearer when you check all source resistors
Patience pays off.
I spent a lot of time running the amp and monitoring Bias/offset readings and heatsink temps.
Bias holds at .173/.175
Offset: near 0.001
Temp The right channel runs 4 to 8 degrees warmer over time. Is that a concern?
Sound is awesome.
