50w Single-Ended BAF2015 Schade Enabled
Joined 2002
Looks correct to me. The speaker outputs from the CCS PCB and Gain PCB will obviously need to be tied together off board before going to +SPKR.
The +28V output from the CCS board will connect to "D" or pin 3 on this boards MOSFET. I caught a little hint from ZM's build. Instead of putting a solderable mounting hole on the PCB. I connect directly with a crimp on ring connector directly on the MOSFET.
Dan
Joined 2002
Gave myself a brain ache here trying to keep up to ZM and Father Pass. That aside, here's a pic of what my final input board may look like with optional buffer.
Dan :eek:
attachment.php
Joined 2003
Big thanks to Dan...My KiCad/PCB fabbing addiction is in full force. I went the 317/337 route as well, but put a 'mini' PS before it.
Joined 2002
When I first inquired about using KiCAD I was warned about the steep learning curve. I found the YouTube tutorials (especially John's Basement) were a huge help and made getting use to KiCAD easy.
Dan
Joined 2002
Rail voltage is 59.6 vdc. Where it's supposed to be 30v it's 1.7V.
For fun I connected a 4 ohm 500W resistor to the CCS 28 volt output alone to ground and it drew the same current (3.3A) and the current was adjustable via the pot.
The heatsink I have the mosfets mounted on is standalone and not connected to the ground of the power supply. Could that be it?
And no current flows at all until I apply about 6-7v bias to the second mosfet.
attachment.php
