50w Single-Ended BAF2015 Schade Enabled
to dantwomey
Hello dantwomey,
I use the 'oldtimers' LM317 / LM337 pretty often. I often add a CRC filter in front of the LMs. There are more modern voltage regulators which produce lower noise.
But I used the LM317 for my 50W-SE-Schade-amp to adjust the bias voltage.
This is a great amp!
Greets
Dirk
Joined 2002
Hello dantwomey,
Greets
Dirk
Keep in mind I am only .1% of ZM. :) Or maybe .01%?
Joined 2002
Joined 2012
Soundhappy, the circuit that you posted has minimum output of 6.25V - too high.
Dan, your circuit has minimum output of 4.54V. That may or may not be low enough for IXFN140N20P. For THF-51S, that is probably too high for a large percentage of samples as the variability of Vgs is high. I used a 5K pot in my build (otherwise same circuit) and that outputted a minimum of 3.0V.
Joined 2002
I have a half dozen PCBs so if I run into trouble I can make up a spare with a 5k pot. Thanks for the info.
Dan
