50w Single-Ended BAF2015 Schade Enabled
One more question, what voltage rating would be needed to use a rotary selector switch to change between the CCS taps? The highest rating I can find on Mouser w/ Grayhill switches is 28V DC. Would that be pushing it? Would that switch see the 28V DC before the output coupling cap?
My solution : 50w Single-Ended BAF2015 Schade Enabled
Point A and B have higher distortion numbers only C or D give better sound imho.
IXYS triode emulation distortion at the center tap C are very similar to 2SK77B
Thanks for the help guys!
I'm actually going to be using the 2SK77B circuit w/ either a 2SK182 or THF-51S and wanted to listen to all 4 positions to pick what I liked best. No offense on your opinions Soundhappy, but since the lower taps are hearing mainly just the SIT with no mosfet contribution...I wanted to at least give those a try. I had seen your implementation, and it is perfect for selecting one of 2 positions, but wouldn't help w/ the 4 unless I cascaded 3 switches which would start to look a bit off 🙂
And thanks ZM...I hadn't thought about the contact resistance issue. I found this badboy:
19001-04UL Grayhill | Mouser
I could give that a try, or else I guess go with the "not as easy to change" method, and use a short large-gauge wire jumper.
Not sure how I missed that switch in the first place while browsing Mouser. Spendy, but I would assume bulletproof!
Ah OK You build with big Tokin's !
I understand better now , try all four CCS taps positions can be fascinating audio experiment
specially with the " Ninja Tune " record label music 😀 Have fun
HAHA...yup! It was my favorite label through college 25 years ago. They still have some great releases, but when the owners sold the company I feel that it slipped a bit. Luckily I still have all my old records!
Thanks for the well wishes. Hopefully it doesn't generate too much heat here in the summer. :redhot: Luckily I'm in Maine, so it's currently been nice and cool so far this year.
Hi Pico,
I would not bias the bottom MOSFET in this way with these parts having such a great transconductance.
I did it only to show how smallest Vgs changes have big effects.
The only thing I would trust is Zen Mods servo solution!
He was so friendly to develop it for me, but I am afraid It will be autumn since I start the BAF2025 amp.
A couple things puzzling me are for one, why is a regulated supply so desirable? And two, later in the thread 1.2 was used to calculate the recommended transformer secondary voltage instead of 1.4. A minor point?
Anyways, I'm highly motivated to build the full 60V version!
Dan
Papa didn't said he used regulated supply , so why should you ?
1.2 for multiplicator is say thumb of rule :rofl: - 1.41 being for unloaded rectifier+filter , 1.2something being for loaded rectifier+filter
when you are walking freely , you 're tall - how much?
when you're walking with cement bag on your shoulder(s) , you're tall how much minus 2 inches
