50w Single-Ended BAF2015 Schade Enabled
Great !
Postman bring me today two 100kuF/80V is for project's with higher voltages.
Caps are large like ~ bench lab psu. Perfect for Schade 50W and Tokin sit's test's.
I pray Mother Earth and Father Cosmos all will be happens.
Thinking about psu and need find nice candidate for Schade 50.
What is transformer secondary voltage to get +60V after filtering ?
Maybe schematic example available ?
Any councils : passive, regulated or other psu ?
Thanks in advance for your answer
I'm using a 60v 900va frame transformer for each monoblock.
It's in choke input, with two stages of choke/cap and with a cheat cap of 1uf I'm getting 60v at the load resistor on test.
The first breadboard amp (of two) is under construction, the circuit board (FR-4 with turret tags) is finished and populated.
Just got to finalise wiring up the input transformer (Danbury transformers interstage) and sorting out the in-out sockets, the on-off switch and fitting the bias transformer and module.
One point to make, the mosfet grid stopper resistors should be fitted as close as possible to the mosfet. I was reminded about that by a friend.The positioning of them on my board (as per picture) was changed before everything was soldered up.
PS I used Duncans PSU designer to model the power supply and providing you input accurate data the results are spot on.
The circuit board work in progress.
I need another amp like a hole in the head but I was there at the presentation so I am thinking about building. It is a hobby after all.
I have a question about the IXFK 120N20P. Is the tab insulated or is it the drain. The datasheet has confused me.
ray
ray
I normally build valve (tube) amps, and I had a pair of DIY audio filament modules in my spares box, and also a pair of 6v toroids, so I am using them.
If I was starting from nothing I'm not sure how I would proceed.
I'm in the process of testing my first prototype, but the heatsink is getting to hot and affecting the voltage readings. A household fan is helping to keep it cool at the moment.😱
Oh yes tube filament circuits with modifications can do it.
My start is from potentialy every bias circuit and his psu possible position.
I get by chance some big heatsinks to experiment but it's not that fearless " car style " class A build by great Diyer 😀
The heatsinks I am using came from a computer UPS power supply and I thought they would keep the two mosfets cool enough without any fans.
It seems the 10K resistor and 1000uf cap on the bias supply make it very slow to react to changes, so bear that in mind.
Those heatsinks of yours look good, any spares ?
Share my joy of received IXYS today
They are example of spectacular quality made semi's.
Vive le Papa Diy !
French distributor Selectronic close all shops and stop deals on line
....i regret was good source for 500 VA r-cores. Some times with promotions : final price less -20 % or 40 %.
I do try find ~ 600 ~800 VA at resonable cost probably Toroidy or Antek 🙂
