i have 3 speakers sir at 1000 watts each,, can this amplifier handle this..?? the amplifier wont be damage..//??
The output from a 54-0-54Vac transformer will be somewhere around 600W to 700W into 2.7ohms.
Will the output devices and drivers survive your operations?
sir my amplifier has output when i test with multitester but when i load 3 speakers it will drop and no audio output,, where is the trouble for this amplifier sir,, good pm....
what are the impedances of the 3 speakers?
assuming they are 8 ohms, when paralleled, it is equivalent to 2.67 ohms. this amp is not designed to run at this very low impedance, so probably the over-current protect triggered the audio cut-off.
B500 TEF
Dear Mr Mile,
I redrew your APEX B500 layout and make it according to your TEF schematic design.
Whether this layout is correct?
For power supply I use 65-0-65 vac.
Is it safe to operate in 2X65vac ct with 6 pairs of 2SC5200&2SA1943?
Dear Mr Mile,
ab class psu
Will they fit?
Half watt are usually bigger and usually have thicker leadouts.
yes it fits,but my question is whats the effect to the amp when i use 1/2 watts instead of 1/4?
The higher rated resistors run a bit cooler, but still dissipate the same heat.
ok tnx.
B600 is the TEF scheme?
scematic TEF.
scematic TEF
schematic and pcb schematil please complete
![djinn :djinn: :djinn:](https://files.diyaudio.com/forums/images/smilies/genie.gif)
- 500W PA amplifier with Limiter
