500W PA amplifier with Limiter
a 65Vac transformer will five you about 90Vdc to 95Vdc
a 65-0-65Vac transformer will give about +-90Vdc to +-95Vdc (190Vdc total across the supply rails).
ClassAB will blow up your 1943/5200 transistors.
Try ClassG, or ClassH, that may allow your transistors to survive.
sir ajt i'm using the original pairs of output 4 2sc and 4 2sa.. but i didnt try yet to supply the 85 volts dc coz i want to ask first before i try the transfoermer
For B500 2x60vAC max, but I suggest 2x55vAC for safety operate.
best to follow designer's comments,
raising the rails while giving you more power,
does not necessarily give you more spl.
using lower rails makes your output trannies
live a little longer than with high rails...
Thnks apex...B500 all succes.
Need Gerbers files for each PCB's
PDF versions of the PCB's are fine for making the PCB's yourselves at home,
but I would like to send the PCB's to a vendor. I have made PCB's myself but
I do not like the mess and nasty chemicals.
Unless someone knows how to change PDF PCB images into Gerbers or
something that software, like Eagle, etc., can understand, then I need
Gerbers files for each PCB. Another option is Group Buys for each PCB's.
Let me know what possible. Take care.😕
