No need to as long as the heatsink is not in contact with the board or other components. I didn't use any.
Thanks Chris
Did some listening to the amp with some full range speakers, Mark Audio Alpair 7 drivers which are only 4" so limited bass but their mid/tops are very revealing.
Overall impression was excellent dynamics/clarity. Top end very detailed without any harshness. Bottom end very clean tho I cant talk to the lower frequencies. Very pleased with the amp so far. I have been building/using "D" class amps in the last few years, the better ones have great dynamics but can get a bit aggressive. The AX14 seems to have the dynamics without so much aggression.
Next step will be integrating it into my active 3-way driving the BG Neo8s mid panel.
You can match them with your DMM, if it has the provision or with your 10USD aliexpress / ebay transistor tester.
apex designs are quite liberal when it comes to matching and use of components.
Thanks Prasi, probability of finding a couple of matched pairs from a set of 20 to 30 transistors is fair enough? As they are cheap INR 5 locally so with 20 its just INR 100 and if I can get the matched pairs then good enough
2N5401 PNP Amplifier transistor : Buy Online Electronic Components Shop, Price in India : electroncomponents.com
I dont know about electroncomponents, but get them from projectpoint.in or eightaudio.in
regards
Prasi
I have brought from them as well as projectpoint and eightaudio. All are genuine sites selling good stuff at reasonable prices. My question was the probability of finding good matched pairs from a lot of 20-30 pieces of 2n5401 is good enough
thanks
Wow, those little heatsinks were sufficient?
It's only for test in seconds, then using bigger heatsink.
This amp has nice sound in mid and high. More relaxing compare to AX-14 or even AX-20.
Nice work
hi mr mile.i finished fh11....and now i need a diy short protection+speaker protection that be very fast reaction...please help me again...with best wishes for you
Use PSU100
YouTube
Use PSU100
YouTube
Hi Mr. Mile,
Can this FX100 PSU be used with Apex A40 amp running at 39v-0-39v AC? If yes, can we leave the PRO out of A40 disconnected?
Thank you.
Sha
Hi Mr. Mile,
Thank you.
Sha
Yes
I finished two boards and mounted on heatsinks, before powering on, I cross checked all the parts and found like for c11 and c12 i used 100uf 63v capacitors.
Do i need to use 2.2uf or can use 100uf too?
Raj
In AX14
- 100W Ultimate Fidelity Amplifier
