No, it's not tested just simulated.
Make a layout and I will test it.
I will, but V10 first
Sure, layout?
Hi Terry, ok.
I will make a layout for A10. Very nice project, I'm really curious to see how the amplifier compared to A9 sound.
regards Olaf
A10 or V10, A10 use 2SK117 FET input.
I'm too. But A10 first.
You can use A10 pcb for test V10 with tube out of bord.
V10 needs a heater circuit for the tube. Am I correct in assuming it only uses half the tube?
Thanks, Terry
Yes, 6,3V to pins 4 and 5 of ECC88. Single tube (dual triode) can be use for stereo amp.
Sounds good. Maybe you can do a stereo preamp using one tube. That would be very interesting.
I do that long time ago.
Awesome! Is it for sharing?
Yes
http://www.diyaudio.com/forums/analog-line-level/162125-tube-ss-preamp-3.html
Looks interesting. Pretty high voltage. I'll have to order some caps. I don't have any that high.
You can use 250V caps instead 400V.
- 100W Ultimate Fidelity Amplifier
