It's this one :
Toroidní transformátor HEFEI TR-T300/2X36V | GM electronic
Should be nice for a stereo setup.
Lucky to have so many.
C9, C10 value
Any body already have LTspice simulation file on this circuit?
For a typical two stage amplifier, C9 and C10 is bad for performance and stability. I would like to change them to 0 if possible.
Regular pole splitting compensation is not used here, what is the consideration?
I made this amplifier for test my home DIY speakers (two way TL).
You can find last simulated version in post #4935
Wanna share?
why not, diy means to share
I believe he means : can you send me somewhy not, diy means to share
share means free right
So there is always new design share by sir Apex
i will check which one that I can build easily
A10 1N4148 corect polarity.
Is there a layout?
- 100W Ultimate Fidelity Amplifier
