check the specification to find what the 36Vac means. Is it open circuit voltage when mains input = 230Vac, or is it loaded to rated maximum AC current when mains = 230Vac?
hi, I have 35-0-35 400va transformers
, will these work for these amps, I have about 50off them
The transformers have 2 x 13v outputs and 1 35-0-35 output
35 - 0 - 35 @ 5A
13v @ 1A and 5A
35 - 0 - 35 @ 5A
13v @ 1A and 5A
Should be nice for a stereo setup.
Lucky to have so many.
C9, C10 value
Any body already have LTspice simulation file on this circuit?
For a typical two stage amplifier, C9 and C10 is bad for performance and stability. I would like to change them to 0 if possible.
Regular pole splitting compensation is not used here, what is the consideration?
I made this amplifier for test my home DIY speakers (two way TL).
You can find last simulated version in post #4935
I believe he means : can you send me some 🙂why not, diy means to share
share means free right 😀
So there is always new design share by sir Apex
i will check which one that I can build easily 🙂
- 100W Ultimate Fidelity Amplifier
