I thought so(the marking doesn't look good), but maybe it is original one...
I saw at post #3317 there are AX-14 also use jengkols (with better marking)
but don't worry I have spares some old motorola 15003-15004 if this one is blown 😀
I will try at rail +/-55VDC for 8 ohm load, is it is okay?
if they were original I believe they wont fail 😀 it is worth to try
I just realize it ... & I will try to redraw it if needed 🙂 & fortunely I have some LM4562 😎
No need to redraw...
Very first draft with mirrored output transistors. Can someone check it please?
A schematic would be very helpful 😉.
regards
I see a inverted 1N4148 make sure all is corrected before you continue, I think the original layout look good no need to redraw 🙂 kind look like vintage style traces I like it 🙂
Juan
regards
Bias transistor must be replaced with BD139 or MJE340 in your pcb.
AX-11 with some very old TO3 output transistors. The power suply is +- 53VDC and it play very good,very silent without signal.Love the sound.
Zoky2
Zoky2
Sorry,here are some picture of AX-11.
Zoky2
Nice work,
A17 CFA
Hello Mile,
thanks for schematic. I will check the layout and then build a version.
For what other transistors you recommend a heat sink or mounting on the main heatsink?
Thank you for a new amplifier 🙂. Feels like an early Christmas
regards Olaf
Hello Mile,
regards Olaf
A9 CFA
dear mr apex,
I want to make a power subwoofer, what type recommended to drive 2 ohm 200 watts speaker
dear mr mile,
thanks mr mile, and what psu recomended for it, vac dan vaA17 new pcb
Outputs and bias transistor are from botom side of pcb... A17 use psu and protect same as AX11.
- 100W Ultimate Fidelity Amplifier
