100W Ultimate Fidelity Amplifier
I thought so(the marking doesn't look good), but maybe it is original one...
I saw at post #3317 there are AX-14 also use jengkols (with better marking)
but don't worry I have spares some old motorola 15003-15004 if this one is blown 😀
I will try at rail +/-55VDC for 8 ohm load, is it is okay?
if they were original I believe they wont fail 😀 it is worth to try
I just realize it ... & I will try to redraw it if needed 🙂 & fortunely I have some LM4562 😎
No need to redraw...
Very first draft with mirrored output transistors. Can someone check it please?
A schematic would be very helpful 😉.
regards
I see a inverted 1N4148 make sure all is corrected before you continue, I think the original layout look good no need to redraw 🙂 kind look like vintage style traces I like it 🙂
Juan
