100W Ultimate Fidelity Amplifier
psu10R
PSU10 voltage regulators require a large voltage drop between the input and the output to function correctly. This requires a relatively high-voltage input power supply and results in low power efficiency. PSU10R low drop linear voltage regulator is a type of linear voltage regulator circuit that works well even when the output voltage is very close to the input voltage, improving its power efficiency. There is +/-15V low drop regulator for preamps.
what current and voltage does this source support sir
apex555 protection
hi
anybody can help me....i made apex555 but when power on after 2 seconds relay be connect.but after 2 seconds be disconnect and again be connect...and over and over....i have two relay....is it for havnt relay driver? if i use bd139 my problem be solved?
Fuego, thanks to you, i have the same for my apex, and i tuned them that day.
You have a virtual beer.😀
YouTube
Beer accepted😀
You have a nice shop.
A40+P30 this is the final version
