AX 14 how it sounds
hello,
i would like to know how this amp sounds and if there were comparison with commercial products?
Where i can look for impressions?
hello,
hello,
Jump boldly.
You will be amazed how good the amps are.
some prefer sound of a-class,others do not. it all depends on you and your taste of sound,how your ears and mind hear it. for me,a-class souns dry,not reach with anything - but that is yust me...
Ok
but i already own an Aleph 30. Will AX-14 beat It?
Worth build it?
Vitopro,my favorite is the A40, but I also really like the sound of the class A.
After much thought, I just made the A40 work in class A.😀
One amplifier was obtained which was very difficult to beat by another.
At least so far.
https://www.diyaudio.com/forums/solid-state/338942-apex-a40-amplifier-build-thread-6.html#post6153096
Can anyone tell which is the best apex amplifier with good sonic character ax or sr or Fh or x with low noise good sound dynamics
YouTube
psu10R
what current and voltage does this source support sir
PSU10 voltage regulators require a large voltage drop between the input and the output to function correctly. This requires a relatively high-voltage input power supply and results in low power efficiency. PSU10R low drop linear voltage regulator is a type of linear voltage regulator circuit that works well even when the output voltage is very close to the input voltage, improving its power efficiency. There is +/-15V low drop regulator for preamps.
What difference between A40 and SR200?A40 and P30 is the best APEX.
apex555 protection
hi
anybody can help me....i made apex555 but when power on after 2 seconds relay be connect.but after 2 seconds be disconnect and again be connect...and over and over....i have two relay....is it for havnt relay driver? if i use bd139 my problem be solved?
hi
Beer accepted😀Fuego, thanks to you, i have the same for my apex, and i tuned them that day.
You have a virtual beer.😀
YouTube
You have a nice shop.
A40+P30 this is the final version
Beer accepted😀
nice work mr fugo....what you do about protection?
- 100W Ultimate Fidelity Amplifier
