DIY Class A/B Amp The "Wolverine" build thread
@ItsAllInMyHead Actually I did have one issue with my mini...I got distracted and put a MOSFET in the wrong spot, had to de-solder and find a replacement. But yes all in all it was very easy for me. I build a wooden enclosure, wired up an a different led power button, as well as rca, speaker, and DC power plugs. I really love that little amp, I just raised the bias a bit and absolutely love how it sounds with my tube preamp. But I just want more power 🙂
Any advice on which version to build?
If you want to have walk through of a Wolverine build using some nice parts check out my YouTube channel linked in my forum signature
- Dan
Reactions: ross51681
An FYI for other builders. I did find an issue with one board. When adjusting bias when I got close to 44mV across TP101 and TP102, it would suddenly jump up to around 68mV, then down, then up, etc. I found it was caused by R109 being at the end of its adjustment range. R108 was specified as 560R in the BOM, I'll be changing that board to 470R and installing a new R109 pot. That will move the adjustment more towards the middle of R109. This was also the board that I had to turn so far to get any reading across TP101 and TP102.
Just a heads-up for everyone. R108 did NOT need to be changed in value. The problem ended up being the IPS board.
Here is the problem and the fix. The IPS board was swapped with another one. Still testing the bad IPS board.
Question for the smarter people on the group. Can I test the IPS and output board together with a +-30V bench supply if I add the 9.1k resistor to the IPS board? I plan to just add one set of transistors to the output board to make sure these last two boards are working.
The BOM has a chart on page 2. Has more to do with your transformer wattage
Transformer for 2 Ch at 4ohms*Expected Continous Power OutRail Fuses F1 & F2
TypicalVAACDC8ohms4ohmsMin Per RailMax Per Rail
50035491001704A10A
60038541202104A10A
70040571502505A10A
80042591602805A10A
90045641803205A10A
100050712003606A10A
Oversized60035491202104A10A
70038541502505A10A
80040571602805A10A
90042591803205A10A
100045642003606A10A
120050712404306A10A
* Halve the VA rating, if you use a separate transformer for each channel
* All power ratings are at 0° phase with a non inductive load
* If using a transformer with a VA rating higher than the "Oversized" section, you should drop the rail voltage by one step, as it will sag less.
* A transformer with dual secondary windings is prefered.
Hi Rick,
The columb "Rail Fuses F1 & F2" should read "secondary volts AC".
Peak current needs to be calculated from the fuse data peak before opening and your SOA of the output stage. Look at elevated temperatures for safe operating area since if you're going to blow the fuse, the output stage is probably hot.
Need some help here,
I tested one board at 30v and it worked fine i
I could do all the adjustments.
Now the other one I saw that one Led (D3) was mounted backwards,so I shutdown and replaised it.
Now the Led lights up as it should.But at R111A (TP107) and R111B (TP108) I get 11v,,,and I can ajust it up some volt with the bias pot.
And after a while Q105 and Q196 gets quite hot..I can adjust CCS LTP pot.
Where do I start?
