Announcing the Wolverine 5th Group Buy - Pre Order Open Now!
Hi Guy'sAfter the success of the past four group buys and the continued excitement around the Wolverine boards, we’re thrilled to kick off another round for the members of the diyAudio community. Your enthusiasm and support keeps this project alive, and we’re excited to roll out the Wolverine V5 Special Edition boards along with some fresh options to elevate your builds even further.
Register for the Wolverine 5th group buy
Once we hit a solid pre-order count, we’ll place the order with our PCB supplier. I’ll keep you posted on progress. After the boards arrive, we’ll calculate shipping, send payment requests, and provide tracking numbers.
A massive thank you for supporting the Wolverine project since our first group buy in March 2022—three years strong!
It’s your passion that makes this amp a reality, and we can’t wait to see more builds come to life.
Best regards,
Stuart & the Wolverine Team
Will check whenI take it that is 1.47V. What voltage do you have across TP3 and TP4 on the IPS board?
I get home. Yes
Its 1.47v.
Sorry, you misunderstood. Measure the voltage drop across R16, labeled TP3 and TP4 on the Input Board. We want to see what is being sent to the output board. You should have about 0.6VDC
Just to check everything you are doing.
- checking input and output board together, with outputs installed, on a 30V bench supply.
- you installed the 9.1k resistor across R17
- You have Q105, Q106, Q107 and Q108 installed on heatsinks.
- You adjusted R11 to 5.0V
- You checked for DC on the output. (what was the reading)
I have not yet intsalled the output transistors.
I have installed the 9.1k resisistor.I am doing these test on 30 volts.
Yes those transistors are on heatsinks
I have adjusted R11 to 5.0v.
The voltage between TP107 and TP108 is 11v
The Q107 and Q108 gets hot so I cant leave the power on for long moments.
Can you post a high resolution photo, from your phone camera, of the board top side and bottom side.
measure between pin1 and pin2 on back of board.edit - make sure R109 is at max resistance to start
- DIY Class A/B Amp The "Wolverine" build thread
