DIY Class A/B Amp The "Wolverine" build thread
Hi guys, I am very close to being able to test my EF3-4 boards V. 4. My speaker protection board and my soft start board are built. I was watching Daniel's excellent YouTube videos for the 100th time, and I remembered that cool, little T ground lift board he used. I realize you can fly wire that thing, but that little pcb keeps everything tidy. Is there a source in North America where I can buy that pcb. My understanding is that it lifts the audio ground just slightly above chassis ground while leaving chassis ground intact. Let me know if I'm thinking about this correctly.
Best,
John
Hi @jminassi
Suggest you get in touch with @fireanimal
BW
Jonathan
I want to bring to your attention an important issue regarding the PCB boards that have been recently circulated. I'm talking about my T-GND and Ground lift boards. It has come to my notice that these boards were copied without my permission or consultation.
As a community, it is vital that we respect each other’s work and adhere to the principles of collaboration and intellectual property. Unauthorized copying undermines the effort that goes into creating and sharing designs, and it’s essential that we all uphold these standards to foster a positive and respectful environment.
I have boards available if anyone would like them. Just send me a PM
Needless to say I wasn't aware of these issues, but thanks for enlightening me
Thank you @plasticator, and I appreciate your openness in addressing this situation. Please rest assured that I have no concerns regarding your purchase. It’s perfectly understandable that you were unaware of the situation.
Your contributions to this project are valued, and I’m glad you’re part of the community. If you have any questions or want to discuss this further, feel free to reach out.
Reactions: plasticator
V4 to V5:
If I would consider an upgrade to V5. Do the boards have the same lxbxh and the same drill-holes? In other words I could use the same power supplies, same box etc.....correct?
I’m pleased to confirm that the PCB dimensions for V5 are essentially the same as those of V4. Additionally, the mounting hole locations and output transistor placements remain unchanged. This means that you should be able to use the same power supplies and enclosures without any issues.
Your boards were not copied, they were improved on and not even the same. Copying would be implying that I took your boards and made exact ones, which I did not, even the layouts are different.
Reactions: hcpower
So the pcb is new and improved , but is the schematic new ? Different component values?
Regarding the new and improved PCB. While the schematic remains largely the same, we have made some enhancements. Specifically, a few additional components have been added to both the IPS and EF3-X boards. A small number of resistor values have been updated. This was necessary to accommodate the changes mentioned in my original announcement.
I'm pleased to share that 100% of the components on the EF3-X boards are reusable, and approximately 90% of the components on the IPS boards can also be reused.
I will discuss with the group the timeline and details regarding the release of the V5 schematic.
Thank you for your continued interest and support!
