Power Supply with Active Rectifier, RF Filter and Super-Regulator
I used DUELUND 12 gauge cast jacket. I had it available and I like it.
The four 10mF caps are on a perf board with the leads in the middle which is likely not optimum but that was the best way to integrate. I can always change it if told it should be linear. I would change it.
The caps are placed so the the leads are available from the bottom (the tops are on placed on a piece of wood) which allows a short path to R25 in my installation.
From there to the stub of the snap in on tombo's board.
I could not take a photo that would show it any better than my explanation.
Reactions: Vunce
Power supply requires only a fraction of volt higher voltage at input to operate at full performance. However, in practice mains voltage variation and ripple at the first reservoir capacitor lead to 1 – 1.5 V required difference.
How much voltage will be available after rectification depends on transformer properties and load. With very light or no load, there will be about 1.39 x AC voltage. Depending on standard transformer loading, that would drop to 1.2 – 1.27 x AC voltage. So it depends on specific use case.
In general, 22V AC is too much and 17 – 18V could be enough. For what purpose would you like to use this supply and what load current is expected (constant or variable)?
19V is required for a Corei3 based audio PC. So the load is almost constant.
Twisted, heavy gauge wire as short as possible would be my approach to connect off-board caps. But, what would be too long for "as short as possible"?
Using AWG 15 – 14 (1.6 – 2 square mm cross section), any length required inside amplifier’s case is not too long for the proper performance. We should keep length at the possible minimum to minimize radiated 100/120 Hz noise. Reservoir capacitors are charged with short high current pulses and that produces strong EM fields. By twisting two wires together, most of two opposing EM fields cancel out, but enough remains.
  • Thank You
Reactions: Vunce
Then 17V AC would be about right. 18V AC is more than required but could be used if taking care for good power MOSFET cooling with external heatsink.
However, I don’t believe that there is anything to gain by replacing LT1083 supply for the PC with a better one. Digital circuits are noisy and, if I’m not mistaken, audio at that PC remains in the digital domain.
Fortunately I have sufficient external heatsink on side panel. it's a 16V 7A transformer. Without load it gives 18.2 V.
Audio PC remains in the digital domain, but when I replaced the standard SMPS to the LT1083 linear supply, it was a big improvement. The same effect happened with ethernet switch. At least I will use it for my DAC. The parameters of your design impressed me, so I give it a try. 🙂
As jean-paul pointed out, that transformer will be fine.
I don’t doubt improvement going from a SMPS to the LT1083 linear supply, but I suspect that it is hard to get further improvement on an audio PC. If you feel like it, report back results. It may help other members with the right decision.
Foundation is ready :spin:.
You nailed it Anand 😉.
That trafo saved me big bucks!
At first, Toroidy was going to get the call🤑🤑
Edit:
The 25V secondaries deliver 26V5 output under load. Perfect for a little regulator dropout headroom.
Regulated output: +/-32V
