Power Supply with Active Rectifier, RF Filter and Super-Regulator
If that was multi-meter’s diode measurement mode measured at the powered down circuit, Q6 seems OK. If that was voltage measured over BE at the powered up circuit, it is not solid confirmation that BJT is OK.
But, Q7 is as well in parallel with D5 & D6 diodes and should be measured as well.
As there is nominal current through D6 & D7, but there isn't enough voltage over D4&D5, one BE junction (Q6 or Q7 or both) may be conducting all the time and limiting voltage over diodes.
In this case, voltages won’t tell us if Q6 or Q7 are damaged. Use multi-meter resistance mode or specific diode measurement mode if available and check BE junctions on the powered down circuit.
Other solution is to replace both Q6 & Q7.
Yeah, I kinda already knew the answer as soon as the question posted. Regulated supplies should be close to the load.
Every time I get the urge to build an external PSU for universal convenience and cost reduction, the cons outweigh the pros and the idea goes away again.
Reactions: poseidonsvoice
@tombo56,
Would building an external power supply housing a pair of R25 modules compromise their performance since distance from the load is increased?
I'd estimate the umbilical cord would be 60cm - 75cm long.
Long wiring defeats regulated supply advantage. Not entirely, as it would still be better than any unregulated supply, but it would be a waste of available performance.
I think that your solution with compact dual mono supply module, that can be transferred between different amplifiers is very good.
Reactions: Vunce
