DIY Class A/B Amp The "Wolverine" build thread
Ah I see you have started with an older BOM. The bias circuit was redesigned. The old one still works but the redesign is much better.
Again, I strongly advise you review, replace as necessary, and populate your boards to the latest:
1st GB BOM - May 2024 spreadsheet
Also make sure you review the latest build guide - and apply the correct updated changes to Q103 and 104.
Do not mix and match parts from BOMs that have the earlier bias parts with BOMs that have the revised bias parts. I’ll link to the post where that change was made.
https://www.diyaudio.com/community/...he-wolverine-build-thread.385920/post-7360185
BOMs and build guides pre may 2023 will have the original resistor and Q103/104 parts
BOMs and build guides may 2023 and onward will have the “revised” parts.
Reactions: stuartmp and Harry3
Yes, I started with older BOM. I have just compared resistor values I used with BOM May 2024 and it looks that my EF3-3 is OK (perpendicular to main heatsink pcb mounting), while in my EF3-4 I used resistor values for driver mounting on the main heatsink as BOM I used did not differentiate between main heatsink and perpendicular driver mounting on 3mm separate heatsinks. Theoretically I could mount my EF3-4 pcbs on the main heatsinks but I prefer perpendicular mounting so I have to change 3 or 4 resistor values. Hopefully I'll manage it without damaging pcbs. Alternatively I can solder additional resistors in parallel as resistors I used have higher resistances.
Yes, I have noticed that mounting of Q103 and Q104 has been changed.
One more question: where could I get these terminals ideally in Perth or in Australia?
I made some progress during the holidays - IPS finished and tested, EF3-4 boards almost finished.
Still figuring out the best solution for mounting the pre drivers to the heatsink, the nut inferferes with the adjuster on the trimmpot. Buttonhead would work but then I won't be able to unscrew the transistor if I have to change it someday.
Power supply layout:
I like this project a lot 😁
I have my initial readings from the left channel and some issues. I used 30DCV and 0.3 amps for power from the DCV regulated supply.
The two Leds on the IPS don't light up.
Otherwise, my readings are within target.
I checked the LED orientation.
Is the LED issue because I've restricted DCV to 30V?
Reactions: Mainframe
