Pearl 3 Burning Amp 2023
If you haven't seen this, and you may have not as it's buried in the thread, post #881 has an interview with Wayne about Pearl 3 and it answers a lot of questions.
Great read, 6L6. Offers so much explanation and useful suggestions. Like the idea of close sk209 matching allowing for lower (or no) R source values. And he explains a little of the harmonic values that can change with different opamps. This appears to be one of the reasons why opamps can sound so different.
Will be spending some time with this and Thanks again.
Reactions: Boydk and 6L6
Good read! I have confirmed the ~60mA based on the PS 5ohm res drop.
Also learned, as I suspected, that the P3 is likely to sound different and perhaps IMO better with high gain setting due to lower feedback.
BTW I found that the V drop across one of the 5ohm res in the PS, maybe the + side?, was a little more 0.29 vs 0.36v. Strangely. I attributed that to the extra red LED. At the time I said screw it, closed everything up connected everything and put an LP on. I may go back and try to identify where the extra current is drawn from.
Reactions: 6L6
This is normal.
I remember user Algar_emi on his pcb´s made room for a 1.5K across the negative 15 volt. It´s only purpose was to even the current draw
from the pos. & neg. supply, if you suffer from CDO (OCD with letters in correct alphabetical order) 🤣
Send me 5 Euros for the stamp/postage, and I´ll send you a nice little variety of resistors
Thank you for the offer, but I already bought a couple of resistors from my "local" store, only cost me € 0,80 and a stiff bicycle ride. We Dutch just love to ride our bicycles 😆 Desoldering and resoldering was pretty difficult (a don't own an electric desoldering pump). Not my best work 🙁.
But now there is something really wrong: almost no sound from the left channel and a lot of hiss and some hum, with both the shield of the power cable connected and disconnected to the RIAA box. Switching the opamps had no effect, and switching the outputs moved no sound to the right channel. As mentioned before my build was completely according to the manual, and all the SMD jfets tested fine. I'm really a newbe with electronics; I have no idea what could be wrong... I did melt off a corner of C26 on the left channel bourd while struggling with desoldering, afterwards I could see a tiny bit of metal. I put a drop of glue on it. But I suppose that will not be the problem?
Here are some pictures. Btw R27 is now 560R en measures 2V9 L and 2V7 R.
Have one P3 where the right channel blinks once at startup and have found it is related to the opamp connection. When loose it will cause this. Check all 4 smds carefully for continuity to their next circle -- this is easy. Do this and the wire/solder joints first.
