Miscellaneous designs - Markaudio, Fostex, TB, Dayton, SEAS etc
The newer 11ms. The ones with no spider sound very good almost
keep up with the bob brines TL’s. They sound best with good power. Sound better with 50 watt F5 than an eight watt SE
Reactions: Vix and LeifB60
Here is some measurements of the MA Alpair 10P-A from rutcho:
https://rutcho.com/speaker_drivers/alpair_10p_a/alpair_10p_a.html
Should I be worried about beaming? Looks to me like a tweeter is going to be necessary to tame the top end. The woden design silbury looks cool, but a lot of work with little guarantee that it will sound better than a multi-way design.
If you look up the frequency response of various high end multi-way loudspeakers, you will see that they are not that flat either. Set then up in your listening room and the frequency response changes again. The graph from rutcho is not of a finished speaker design, it is raw driver response. The ultimate question is what the final balance is like and if you like that sound. I have a living room that has too many reflections for many loudspeakers, the beaming of large (8"+) fullrange drivers has been a benefit to me. In my home office, with a much better damped acoustic, it wouldn't work for me.
@Scottmoose, a quick question about the Cirrus enclosure. I am experimenting with some composite decking sheets I have left over from a construction project. The pieces are 5.5" (139.7mm) in width.
I can cut them for a thickness range of 18mm - 25.4mm. They are at least the equivalent weight of MDF, maybe even heavier.
Can 139.7mm be substituted for the 154mm width of the enclosure ?.
MM
Thanks for the responses. I have some buyout 3" dayton drivers and 3/4" tweeters that I was going to model a small desk top speaker system with. So just as an experiment, I will pull out the DATs and try some measurements with these drivers and the composite decking enclosures. Will use J.Bagby Quarks and Mattp 60 minute dsa's for a guide.
MM
Reactions: GM
