Moray James.last tom waits
xrk971.
on the first recording ,take it with me ,i had to lower the volume of the veneer panel as the piano was setting off the problems with splitting and cracking surfaces .
but then i noticed that something else was also distorting , the low frequency from the TLS was causing at least 2 items in the room to start buzzing (still not located ).
so ive had to lower the TLS which only run below 300hz,so his voice does not sound as deep(would you believe )as it would, which i think is much nicer and gives more warmth and closeness ?
the second recording, filipino box spring hog,i recorded to show that i wasnt just playing soft music , because the panel could not handle it.
i had one finger in one ear and turned my head to one side when playing this, and i was well back in the room, as it was quite painfully loud
obviously you do not have to listen to it this loud
sorry they are in the wrong order, i had to change ,take it with me , to 128 , as it was too large, even though at my end it said it was not ?
steve.
I would not worry about not having enough DBs from small panels.
This recording of Filipino box spring hog , is a torture track for any type of speaker ( not just because it is Tom waits 🤣)
As I explained in this post, I was playing the track very loudly, far louder than I would ever normally listen.
It is a very raw recording, and he is shouting most of the time.
There is no compression or strain from the panel, so it is hard to tell just how loud I am playing this track, from listening to this recording.
Believe me when I say, I was in pain listening at this level, during the recording!
Steve.
Panel size does not influence efficiency, only the bottom end cut-off.... how much larger would a panel need to be to play appreciably louder than that one would (I guess I should ask hoow loud that one willl play with subs) assuming that the bass roll off of the larger panel was adjusted to match the smaller panel? I cannot seem to understand how small or how large I need to build. I would be happy with the ability to play average level of 95 db and peak capability of over 100 db db. I don't often play this loud but some music just calls for those levels to feel right. Is this expecting too much from a small panel? thanks Steve.
Efficiency, loudness, is a function of panel density and stiffness. A very light panel made of EPS is probably more efficient than any other material, but it's extremely mid-range heavy. A large EPS panel can have very nice bass, but you will have to do something about the HF.
Hi Moraydo you mean that rather than the corners going to a long point that they wold have a small semicircular notch at the end which would result in two smaller points at each corner? I hope this makes sense.
No... Just a radius to the corners...I visualise this stuff a lot, and if you point load a flexible membrane like cloth (ignoring the effect of the added stiffening in this case), then the least energy deflection shape is circular, so forcing a rectangular shape causes distortion at the corners, which can be reduced by adding a radiuses fillet to each corner of the frame. This in the will allow the sharp peaks in Andre's stiffening to be reduced/modified
Eucy
and I thought I just got caught up!But...don't forget about these threads too:
https://www.diyaudio.com/community/...r-dml-design-and-analysis.383567/post-6954047
https://www.diyaudio.com/community/...ing-of-dml-speaker-panels.394465/post-7234486
https://www.diyaudio.com/community/threads/dml-pa-systems.390363/post-7124792
Thankfully they are much shorter!
Eric
I also found this thread very interesting and is still valuable. Unfortunately it came to an abrupt end.
https://www.diyaudio.com/community/...ndwich-dml-panel-construction-project.300581/
I did a test tonight with the panel mounted in my 2x6 frame with baffles mounted, and then I carefully removed the 15" deep long side baffle without disturbing anything and retested, and the results were almost the same. Only tiny differences. My previous tests by hand must have skewed the data. Either that or the frame's built-in 6" baffle is enough and adding 15" to one side is insignificant.I used some scrap chipboard to make an L that I mounted to the back of the frame. It's about 15 inches deep and runs a bit further than the length of those 2 sides. I used duct tape around the entire panel-to-frame gap for a seal but I don't think that worked very well so I'll have to figure something else out. The frame is made of 2x6 so it's already got at least 6" of baffle built in all the way around. This was my first test and I haven't had time yet to experiment with baffle sizes. Building a driver brace is a higher priority right now, as is my day job...
Bracing the two short ends of the panel made an improvement by itself but it was a bit lumpy. The baffles added more and smoothed it out.
I never really thought about baffles in the past because the panel itself looks like a baffle (self-baffling), but there's a lot of interaction between the front and back near the edges. The smaller the panel the more intense that is. You can feel it in the air with your hands near the surface and hear the weirdness with your ears if you inspect the edge of an unsecured panel while it is playing. I figure that baffles should dilute that front-back interaction resulting in higher efficiency and less distortion.
ok so level is not going to be an issue do you find any difference in terms of the amazing 3D spatial sound between a small 6x9" panel and a larger one say 9x12" ? thanks.Moray James.
Steve.
I think there are a couple of factors that contribute to the "3D spatial sound".
First of all of course the phase incoherent waveform patterns that is emitted rather a single waveform, making it sound spacious and encompassing.
The second is that transients are very pronounced, which makes stereo imaging very good, which otherwise would be a bit unexpected for a more diffuse signal.
I don't think there is a big difference in neither spaciousness or imaging between reasonably sized plates. My impression is that larger plates can have a bit longer decay times, and smaller plates sounds a bit tighter, but both still sound very much DML.
Also something I suspect, but have not confirmed, is that the cluster of four exciters have better spatial imaging than using a single exciter. We use initial transients to determine direction of a sound, and they come from the piston action introduced by the exciter. And with a single exciter, the area emitting that is only the area in the mounting circle of that exciter. If you have four exciters close together, not only do you have four times as much area that is directly following the exciters movement, and hence producing transients, but the area in between them becomes coupled and makes it like one large ring.
your comment about four close exciters makes me wonder about multiple single exciter panels. if one were to use say four panels (two per channel) does anybody have any experience with doing this? if so do the two panels per channel present a larger sound field if spaced closely or wider apart? Thanks.
I use four panels per stack to be able to deliver enough power, but I would think that the ideal is one source of transients. If you have multiple, if they arrive at exactly the same time we should interpret the signal as coming from the middle of the sources. But if you are off axis and have different arrival times, the transients would be a bit smeared.
In practice I found the imaging amazing also with multiple plates, but if you don't need that much power I would think a single plate should offer the best imaging.
thanks very much for your input I would expect that room acoustics will play a major factor in using multiple panels per channel especially so if the panels are space apart.
At a guess I would expect a pair of small panels in front of you to the left and right similar to a conventional stereo set up along with a second set of stereo small panels set up farther away from you (to increase arrival time from the front pair of panels)
with some tweaking in the set up I would expect a larger perceived sound field than with a single pair of small DNL panels, especially if the second set of panels can be situated to the back side or to the rear of the seating position. This is however mere speculation on my behalf at this time.
I have been further researching Mycelium Board, where straw from Rice and Wheat is a substrate, there is also Coffee Waste being referred to regularly as well.
Boards Density is at present being seen to double across the designs being produced, with a Kg per m/3 ranging from 57Kg to 99Kg.
This will offer at the lightweight end of the scale a 1000mm x 1000mm x 10mm board at 0.57 Kg ( 20oz) per / m2
A 5mm thick Board which I assume will be the go to thickness is 0.285Kg (10oz) per / m2.
Mycelium Boards using the above production materials are becoming popular at thicknesses between 25mm - 60mm as a Insulation material.
The Market is growing, expect to see this product in broader use and a increased variety of Board Thicknesses.
At the moment the most common work is being done in Countries where a concern is being expressed for Circularity in the Economical Strategies.
Holland and Spain along with Scandinavia, this is early doors and the interest is growing, unfortunately the coverage on the Web is Sporadic.
I will search out any Mycelium Boards being produced in the US, there might be University producing product, I was once in communication with a American University about their producing Delignified Translucent Wood Panels as a Glass Substitute.
This most recent find might be of interest.
https://www.etmm-online.com/innovat...-speakers-a-5ef4a9e16cdb80e626083af0a6ff611f/
There is very little difference between these two sized panels.ok so level is not going to be an issue do you find any difference in terms of the amazing 3D spatial sound between a small 6x9" panel and a larger one say 9x12" ? thanks.
Being small they will give excellent stage depth and sound field.
just like a point source should.
Steve.
Yes, the easiest way to add more space is to add another dimension. I prefer sound coming from all directions, and I wish I had space to have a quad sound setup in my work room/studio. Even if only listening to a stereo signal it does feel more encompassing being surrounded by speakers.thanks very much for your input I would expect that room acoustics will play a major factor in using multiple panels per channel especially so if the panels are space apart.
At outdoor parties I always rig sound from four directions, and since the imaging is soo good I now have decided to make a set up so I can send quad sound from my DJ setup. There is hardly any music available mixed in quad or surround unfortunately, which is understandable. Usually stereo is almost a waste on a PA system anyway, since most people will be far from the small spot where you actually get good imaging. But with DML, when standing next to one stack I can hear the transients from a stack on the other site of the dancefloor. So that should make a quad sound setup a lot more interesting, and for now I will just play around with some quad panning and fx when mixing tracks.
Moray I think you might find that room acoustics have less effect on DML panels than with pistonic speakers. Weirdly, DMLs don't seem to activate the resonant modes as much as cones do.thanks very much for your input I would expect that room acoustics will play a major factor in using multiple panels per channel especially so if the panels are space apart.
This is all probably to do with the diffuse wave front that they produce, DMLs do not produce a solid wave front across the spectrum. Visualise a pebble vs a handful of fine sand dropping into a pond (credit to whomever it was that used this image before on the forum.)
DMLs already provide a much deeper sound-stage than cones do. The sound appears to come from behind the panels, and it's quite disconcerting for somebody who's very used to traditional box & cone speakers. This could be more apparent in panels that are under-damped, as the sound might ring a little more than they should, and therefore give a little artificial 'reverb' to the sound. It also tends to smear the attack of lower frequency instruments, especially kick drum and floor toms.At a guess I would expect a pair of small panels in front of you to the left and right similar to a conventional stereo set up along with a second set of stereo small panels set up farther away from you (to increase arrival time from the front pair of panels)
A properly damped panel should provide a crisp, clear bass end, with the panels disappearing from the aural 'view', while still retaining a deeper sound stage than with boxes and cones.
If you want to add a bit of ambient back-fill behind your listening position, then you could a take left-minus-right configuration and install two panels out-of-phase with each other. This will provide a massive 'feel' to the sound. Not completely Dolby 5.1, but good enough for casual listening.
- Full Range
- A Study of DMLs as a Full Range Speaker
