Apex AA14 Amp Class A 24V Supply
Or do what printnik did and remove this biasing subsystem completely, and replace it with traditional Vbe multiplier (which normally is not needed in A class amps). The whole (and only?) interesting thing about AA14 was the novelty biasing circuit; without it - it's totally 'normal' amp, that might not be worth building, given all these troubles so far, unless someone puts some time to sim it properly.
replace it with traditional Vbe multiplier. 50ma bias.
Hi
a played around and think to rebuild this amp and try it.
my final setup is, because i have 4R speakers.
R12_220R, R14, 91R
Rail is in my FW amps normally about 22V rail (or little less)
bias setting for class A:
R16 332 bias is about 1,45A
R16 bias setup is 1,67A with 316R ..my setup what i choose
R16 bias is about 1,9A....be carefully here..
Gain is according to mineks setup 21,5dB with R5 2k and R15 22k
with 1,4Vp input into 4R it is the max of about 35Watt
with 1,5Vp into 8R you get about 20WATT
actually i am not able to do more LT spice sim...have to learn...
chris
Hi. I added emitter resistors to the differential stage for better phase margin.
  • aa14_chris_printnik_vbemultiplier_bias setting to 60mA 4R__22Vrail.asc
Reactions: chermann
Hi Minek
I check all resistor values - okay
diodes ok
all small BJT ok.
bigger BJT okay...
then i realized that the onsemi 1381 NPN is with hfe about 150 too much for the "auto biasing function" because if i change to the BD137 and BD136 which i had in the box- both amps are working and the ocp is not get on.
bias is starting with 1,44A @ 24 Volt and goes on one amp quicker then the other down to 1,250A
okay fine. but...
i had on the speakers measured the DC offset and i got at start up of the PSU 15Volt !! and then it gets more or less slowly down to 5V.
****.......this is bad!
so enough for today...
chris
"had on the speakers measured the DC offset and i got at start up of the PSU 15Volt !! and then it gets more or less slowly down to 5V."
I have the same problem with DC=18V. You can try to remove diode D1.
After removing, the amp started to work great and DC offset was 2mV.
Small signal transistors are BC550/BC560.
Reactions: chermann
Fine !
I was a bit blocked because minek (well amp builder = expert) wrote that it is nothing special and its not worse a try. post 89)...so i slow down.
which transistor do you use for Vbe multiplier? is the TO92 as printnik supposed enough for class a biasing?
ok..thx.
you just remove the D1 and keep the auto bias transistors? or do you remove the auto bias circuit (abc) completely. i am asking because minek told that it has with abc the amp has bad THD.
what is your bias actually?
do you have pics?
thanks
have fund
